A couple ?? 4 you techie's
Old Jan 9, 2003 | 10:53 AM
johnsg35's Avatar
Hello Everyone, first time user & poster. Love my G35. Had to wait 18 weeks to get it (customer ordered) but worth the wait. Anyway I was wondering about a couple things:
1. I see the coupe is rated at 280hp. Is it an easy adjustment for a shop to bring/add 20 hp to the sedan? Will it nullify my warranty?
2. I wish the sedan had dual exhast like the coupe. Is this also something that can did done relatively easy?
Thanks
Old Jan 9, 2003 | 11:01 AM
Rumble's Avatar
Re: A couple ?? 4 you techie's
1. In terms of boosting HP ratings to +20HPs, it is possible, but there is nothing at the moment other than air filter changes and exhaust systems. Those will not make 20HPs though. Just wait it out and depending on where you get things done. If you get it outside of Nissan/infiniti, it will void your warranty on that item changed.
2. I would not change my muffler system to dual exhaust if it is not produced like that from the factory. Splitting the exhaust from one muffler or changing the car to have 2 mufflers will only decrease your power ratings.
That's my opinion, if anyone disagrees they are more than welcome to explain what they think.
<img src=http://members.rogers.com/choi2690/Rumble-G35-sig-02.jpg>
It's still nothin but a G thang
Old Jan 9, 2003 | 12:24 PM
pestilence's Avatar
Hi Johnsg35..
I think the difference lies in the ECU chip.. I think i read on this board that there was some talk/rumors about flashing your ECU to the coupe ecu... or somthing like that..
..pestilence..
Old Jan 9, 2003 | 11:04 PM
mbarrad's Avatar
Must be a combo of the ECU and the exhaust. The engine stats on both the C and the S are identical. The coupe is also heavier.
Limited Edition Twilight Blue / Premium / Graphite / Xenons
Old Jan 9, 2003 | 11:08 PM
KongzGx's Avatar
yo Rumble,
that's a nice pic of a modded up G35 that you have as your signature.. if i were jayme ong, i'd take a double take too.. when is your car gonna actually look like that?
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Old Jan 9, 2003 | 11:58 PM
Rumble's Avatar
KongzGx > Haha!! I dunno, all depends on my job situation. Earliest would be this spring/summer. Latest will be the following spring/summer. I want...i want LOL
Old Jan 10, 2003 | 12:24 PM
pestilence's Avatar
Im really looking into getting the Gialla body kit... Its just too damn expensive... around 2k to get it here... then another 1-2k for installing it (modifying back bumper.. has some sort of problem)... Maybe somone (cadillaccarl) *ahem* should import them and some how find somone to modify the back bumper and resell them... )
..pestilence..
Old Jan 10, 2003 | 12:43 PM
KongzGx's Avatar
same kit as that on rumbles sig.. don't everyone go out and get this same kit now.. haha..
it's nice.. but i like to have a reasonable amount of clearance.. i find i don't like having to bow down to those dreaded speed bumps.
Old Jan 10, 2003 | 01:05 PM
pestilence's Avatar
If you see it in person.. or go look at the Teckademics feature G35 you will fall in love with it.. haha atleast I did.. it just looks so clean and makes the front look so.. pretty (i guess pretty isnt the word to use.. but you should get the idea).
..pestilence..
Old Jan 10, 2003 | 01:08 PM
KongzGx's Avatar
yeah, i like the way a lot of cars look when you add kits and such.. especially in movies.. but then i remember i live in the real world.. and moreover.. i live in houston, which has some of the worst road conditions due to its constant construction, so getting a nice body kit just isn't ideal.. it'll be good for a while, but then i'll hit some debris or fall into a pot hole, scratching and scraping it.. sooner or later, i'll want to replace the kit.. just too expensive for me.. so i'm happy with the kit i have on it now.. even tho i worry it'll be expensive to replace that one too if i had to.
Old Jan 10, 2003 | 01:27 PM
Dan_1's Avatar
johnsg35,
I've researched this myself, being i'm getting a MT6 sedan.. From the peeps i've talked to and the specs, the only difference between the Coupe and the Sedan is the Exhaust and Body Panels, otherwise its the exact same car.... The dual exhaust from the coupe will bolt onto the sedan.. the only mod you have to do is trim the rear bumper for the 2nd exhaust pipe.. this shold give you the same HP rating as the Coupe... I know www.g35accessories.com was selling the coupes dual exhust for sedan owners for $900, but for some reason they have removed it from there web page.. I'm guessing since they were a Infiniti dealership, Infiniti found out about it and made them remove it... As i've metnioned before, soon as I get my car in April I will be doing this mod. I'll dyno test it and post the results...
KallDay86
Jan 8, 2016 12:42 AM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
Visionnn
Oct 3, 2015 05:16 AM
hrdwirk1
Oct 2, 2015 06:34 PM
