MREV2 or spacer?
Old Jun 5, 2006 | 02:19 PM
Kingfanpaul@sta's Avatar
MREV2 or spacer?
I have a 03 sedan and ive done alot of searching and cant determine whats best. Should i get MREV2 or a plenum spacer since I cant have both without tuning.
Old Jun 5, 2006 | 06:14 PM
godmans's Avatar
For price, I would go for a spacer; for stealthy look, I would go for MREV2
+ current dynos show that they show similar gains
Old Jun 6, 2006 | 03:26 PM
MI SO FST's Avatar
Is there anyway of doing both with more gains??? I have also been looking into this as well and havent found the best way.
Old Jun 6, 2006 | 03:32 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I went from the spacer to the MREV2.
JM2C...
While not a huge difference, MREV2 is the way to go.
The biggest thing is that MREV2 balances air flow... the spacer does not.
I can definitely feel the engine is smoother running.
Old Jun 6, 2006 | 05:29 PM
MightyG35's Avatar
One more question for all the gurus... How about MREV2 vs. the Kinetix Manifold? Which will yeild more HP gains? And if going FI, would you use the MREV2 for the even distribution of air?
Old Jun 6, 2006 | 05:35 PM
Hexxum001's Avatar
First of all, unless you have the Rev Up motor, you will need to do a reflash if you go with the MREV2 and a spacer or else you will lean out. Secondly, the MREV2 is the lower plenum and the Kinetix V+ manifold is the upper plenum so technically you can get both but once again, without a reflash, you will lean out. If you are talking about the Kinetix SSV, that is a different story. For those with the Rev Up engine, the best combo per Tony @ Motordyne is the MREV2 + the 5/16 inch spacer. Rev Up motors shouldn't need a reflash but you can definitely optimize your gains if you do a reflash or go with something like a UTEC.
Old Jun 6, 2006 | 05:53 PM
godmans's Avatar
For non Revup, I would really recommend a MREV2 over a spacer because for the stealth reason. HOWEVER, for gains, dyno runs (available so far..) show that 5/16" spacer and MREV2 show very similar gains.
Thus, IMO, if you can find a good deal on a 5/16" spacer, go for it..cause the MREV2 now costs around $222 (the discount was over...)
Good luck modding
Old Jun 6, 2006 | 06:09 PM
MightyG35's Avatar
Sorry... yes The SSV. Hexxum and godmans.. more info please. Ive read the thread on the dyno testing, and yes very interesting:mrev2+spcer vs. no spacer, similar gains. But the ssv?? will it be more substantial?
Old Jun 7, 2006 | 09:57 AM
godmans's Avatar
1) SSV, I have never seen any dynos that show comparble gains to MREV2 or spacers on a NA VQ35
2) MREV2, has more average horsepower gain when compared to 5/16" spacer (there are a lot of dyno plots on this..)
3) 5/16" spacer, cost less, has a bit more up top, but doesn't give that much gain in the mid-range when compared with MREV2
4) MREV2 + 5/16", so far, as myself and Wired24/7 from 350z.com have experienced, you either get a tune or you are risking the ecu pulling timing to correct the lean situation from this combination (test pipes and aftermarket cats would only make the lean situation worse)
5) Nutshell, get MREV2 and stick with it or get a spacer if you can find one cheap; go for both if you can afford to pay to get a proper tune
G/L
Old Jun 7, 2006 | 03:43 PM
MightyG35's Avatar
thanks. Now if I can get to Jim Wolf and get tuned.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
