DIY: In Cabin Filter Replacement
Old Jun 9, 2006 | 07:52 AM
Lazer's Avatar
I tried search, and tried g-owners.com ( that page doesn't load today ) Does anybody have the detailed instructions for an 05X?
Old Jun 9, 2006 | 09:06 AM
rupdog326's Avatar
Out of many - one people
Here you go. http://www.infinitihelp.com/Ownershi...AirCFilter.htm
Old Jun 9, 2006 | 09:18 AM
Lazer's Avatar
Thanks:d
Old Jun 9, 2006 | 03:41 PM
Lazer's Avatar
Problems with cabin filter install
Ok, I followed the instructions for dis-assembly and got to remove glove box. However, even after removing all the screws shown in the How-to, the glove box was stilled locked in place.
I put it back together for now, but would like someone who has done this to explain how to remove the glove box after removing the 4 screws and the latch.
Old Jun 9, 2006 | 03:48 PM
harley01's Avatar
http://www.imagestation.com/album/?id=4290074637
There are two clips under the dash to the left and right of where the latch was located. You need to pull donw on the entire dash, not just the glove box. The link may help provide a better visual reference.
Old Jun 9, 2006 | 04:13 PM
Lazer's Avatar
Thanks, that helps a lot. I wasn't sure how hard or where to tug on it After I stop the bleeding knuckles, I'll tackle it again.
Old Jun 10, 2006 | 08:56 AM
Mr. G's Avatar
Harley 01 is that your visual instruction manual on image station? That's great.
Old Jun 10, 2006 | 09:15 AM
Mr. Wonderful's Avatar
Thanks harley01... that will help a lot of us with this job.
Old Jun 10, 2006 | 01:12 PM
DieselX's Avatar
+1 for Harley
Old Jun 10, 2006 | 02:20 PM
ABQ_G35's Avatar
The only trouble I had with this, (on my '04) was getting the trim piece at the door back in place, I couldn't get it back to where it was. Anyone else?
Old Jun 10, 2006 | 08:14 PM
sliderg35's Avatar
Give it a good whack with your hand.
Old Jun 10, 2006 | 09:42 PM
ABQ_G35's Avatar
Seriously, I'll remember that when I change the filter on my '05, I was afraid to hit it too hard.
Old Jun 10, 2006 | 11:46 PM
mikeee2's Avatar
I had the same issue today when I changed the in-cabin filter. Are you talking about that cover with the clip on the right? I was pushing the clip and it wouldn't go back. If I push any harder the clip would break... I might of bent it a little too. Then.....I realized all you had to do is take your palm and push the cover in the middle and it snaps right in. DUH!
Old Jun 11, 2006 | 12:08 AM
ABQ_G35's Avatar
This is it.......
Old Jun 11, 2006 | 12:47 AM
mikeee2's Avatar
This is it.......
Oh....that one. I didnt' have any issue what that at all. I think I snap the long strip on first then the side panel just push it in.
