Calling all "X's" with a lowered suspension!
Old May 9, 2011 | 08:55 PM
  #1921
mcaron's Avatar
Originally Posted by lowerd4lyfe
Haha your a funny man Mike.....I will get that pic for you tmrw unless someone has one available now. It would be greatly appreciated. Every shop i talk to recommends replacing the axle since your taking the spline out of its factory position. Are there certain tools i will need.
Mike it would be 10x easier if u would just drive on over here and show me how
hahaha pay my gas and i would love too :P i just recently did this 2 weeks back, guess i should have taken pics, just hard when my hands are full of axle greese lol
Andways only tool you will need once you get the axle off is a pair of snap ring pliers to get the snap ring off, so you can slide the bearing off the axle to you can slide the new boot on.
Heres an example of a pair of snap ring pliers but you can get them at harbor frieght of like $4
Amazon Amazon
Old May 9, 2011 | 09:07 PM
  #1922
mcaron's Avatar
anyways try to get pictures of the side with the rips boot, I'm assuming its the passenger side since thats the side with the shorter CV shaft. Just snap a few pics, make sure they are close up, but not too close to the point where i cant even tell what im looking at lol
Just make sure you get like the whole knuckle assembly in the picture, get it from lol the top, left and right of the knuckle as if you were starring directly at it.
For example take pictures from inside the wheelwell in the directions on the arrows i pointed out in this picture, just so i can point out the nuts/bolts you need to remove to do this job(this is a driver side, yours will be a passenger side) but i still need photos in each direction
The more pics the more i can help you out :]
Old May 9, 2011 | 10:54 PM
  #1923
lowerd4lyfe's Avatar
Ha okay... ill stay counting my pennies!! Lol
And mine is the driverside cant tell if its inner or outer. I can look down beside strut tower and see lube splatters on different parts. I ywould assume its the inner since it was on my exhaust components. But i will try to snap some pics of it tmrw after.work. i just talked to my mechanic that work for issan and he said by the ime i get te boot.and install it, id be better off spending a few more dollars and replacing the whole axle..he said nvot to get a boot from pepboys bc there prolly.cheap. where did.u get urs and do they last
Old May 10, 2011 | 08:50 AM
  #1924
rpm&my_G35's Avatar
I am surprised at how expensive it is. My Mechanic ordered the boot from Nissan, removed the shaft and replaced the boot. He charged me $182.00. Surely there must be a trustworthy mechanic in PA that will do this without gouging you.
I had a couple of them recommend I replace the whole shaft but IMO that's their way so they don't get their hands dirty.
Like mcaron says, it's not hard to do so any real mechanic should be able to do it in an hour or so.
mcaron...I'm still curious if you are removing yours or wrapping it. 30 min seems quick to remove, repair and replace all the components.
Old May 10, 2011 | 10:37 AM
  #1925
yeah I have a few shops to call today....
Mcaron, theres only one way to find out, if you can do it in 30 mins. Have someone witness it...That someone being me! Pack your bags! LOL
Old May 10, 2011 | 12:07 PM
  #1926
iiiiiekoiiiii's Avatar
u guys are really makin me wanna change mine =[
Old May 11, 2011 | 12:09 PM
  #1927
mcaron's Avatar
im removing the whole shaft, its 3 nuts lol take off wheel, remove axle nut, remove brake caliper and rotor, remove 1 nut, rotate knuckle, slide axle out. done.
Old May 11, 2011 | 09:08 PM
  #1928
bobbybg11's Avatar
here's before Pics
After pic Megan Coilovers
Old May 11, 2011 | 11:35 PM
  #1929
GXXXV X's Avatar
looks hella VIP lol nicely done!
Old May 13, 2011 | 03:25 PM
  #1930
mcaron's Avatar
well then, my axle boot ripped again after about 2 weeks....great. so once i fix it i will make a diy for everyone
Old May 13, 2011 | 06:21 PM
  #1931
FlyingLumpia's Avatar
Makes me want to trade mine for a rwd only if the dealership would let me switch the stock kit for the nismo
Old May 14, 2011 | 11:43 PM
  #1932
mcaron's Avatar
^your telling me, i have ripped 4 cv boots so far, and it doesnt stop, i would max my coils out/pull rings, do everything to be ON the ground lol
Old May 14, 2011 | 11:58 PM
  #1933
You know thinking about it when you lower it the axle is no longer straight more at an angle now. Well I was told the 240 guys put spacers on the engine mounts. I wonder if we did that it will lift the engine up some so the axles are more even.
Old May 15, 2011 | 04:13 PM
  #1934
mcaron's Avatar
seems like alot of work to me? lol
Old May 16, 2011 | 11:01 AM
  #1935
Infiniti called today, my boot is in, so Im fixing it tomorrow after work. Hope this is the first and last time, this damn thing needs replaced!!!!! Mcaron I dont know how you can do it over and over!
Question to the guys with BC Coils on I have my rear raised I think as High as my coil allows and its barely cleared the stock tire. i have about half inch left of the spline that goes down thru the coil. Does this seem right to anyone? (its the newer coil, so I didnt use the gold cup on the bottom of the coil, just FYI)
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
