Calling all "X's" with a lowered suspension!
Rating: Thread Rating: 3 votes, 4.33 average.
Old May 8, 2011 | 07:59 PM
  #1906
FlyingLumpia's Avatar
check your brake fluid to see if it is low also.
Old May 8, 2011 | 08:07 PM
  #1907
lowerd4lyfe's Avatar
Is this for me? lol.....if so, could this cause the slip and vdc light to go on?
Maybee from removing the factory strut...and taking off the brake light nut??
Old May 8, 2011 | 08:24 PM
  #1908
Yes its for you. There is a brake light nut?
Old May 8, 2011 | 08:36 PM
  #1909
My bad I was on my phone and typing 2 things at once. I ment the nut that hold the brake line to coilover. Would the low brake fluid cause the slip/vdc lights to come on?
Old May 9, 2011 | 08:40 AM
  #1910
rpm&my_G35's Avatar
Definitely.
...and the new ride height looks great!
Old May 9, 2011 | 09:46 AM
  #1911
Originally Posted by rpm&my_G35
Definitely.
Weird...never woulda thought that...Ill have to check that.
Also I checked under the car last night. It appears to be the inner CV boot.
Thanks , I think I will be raising it alittle to prevent the Boot to be torn again.
Old May 9, 2011 | 12:19 PM
  #1912
mcaron's Avatar
lowered4lyfe, you can just replace the cv boot, ive replaced mine about 3 times on my own saving a shop from charging me 150$ for a job that takes 30 mins, you DONT need to replace the whole axle
and your steelingwheel is like that because you need an alignment
Old May 9, 2011 | 02:19 PM
  #1913
How hard was it to replace your boot? Was yours the inner or outer?
Any special tools needed? Yeah I would like to replace it myself the part is only like $25.00. Screw paying $125 for labor.
Thanks for everyones help.
Old May 9, 2011 | 02:26 PM
  #1914
rpm&my_G35's Avatar
You replaced the Inner CVJ boot in 30minutes?
just curious...are you removing the driveshaft and sliding a new one piece boot on or just putting on one of those wrap around CV boots that you need to seal. From what I'm told, those don't last very long.
  #1915
apintojr's Avatar
yes. low brake fluid levels will set off ur VDC/Slip light. experienced this myself about 2 years ago.
Old May 9, 2011 | 02:33 PM
  #1916
rpm&my_G35's Avatar
Here is an example of properly replacing a CV boot. You need to remove the shaft. This guy does them quick because he does hundreds of them. Getting it off your car will take some work.
Old May 9, 2011 | 04:44 PM
  #1917
Looks like a good video..but i wouldnt have the slightest clue on removing it. I checked my brake fluid and its full..so im guessing its the alignment that threw the lights on. My question is, can i get an alignment and then next week get the boot fixed or will getting the boot fixed screw up the alignment?
Old May 9, 2011 | 05:04 PM
  #1918
Local garage wants $350 to replace the boot...Outrageous!!
is this something a franchise shop can do...ie Monroe, Midas, Sears, NTB??
Old May 9, 2011 | 08:28 PM
  #1919
mcaron's Avatar
Guy it is VERY simple to change the CV boot, the one i keep ripping and replacing is the on farthest from the wheel (not sure if its the inner or outer).
If someone can get me a good picture of the wheel well with the wheel off, like one side angle shot and one from inside the wheel well looking down on the knuckle, I will circle which nuts/bolts to take off and how to do it so i can save you guys the RIDICULOUS price. Honestly i can get this done in 30 mins if i rush, shiet i can make 600$ an hour replaces axle boots.
"Mikes CV boot replacement" hahah
Old May 9, 2011 | 08:42 PM
  #1920
Haha your a funny man Mike.....I will get that pic for you tmrw unless someone has one available now. It would be greatly appreciated. Every shop i talk to recommends replacing the axle since your taking the spline out of its factory position. Are there certain tools i will need.
Mike it would be 10x easier if u would just drive on over here and show me how
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
