Calling all "X's" with a lowered suspension!
Old Mar 29, 2012 | 10:36 AM
  #2296
Bastone's Avatar
Originally Posted by JAYRIPPA420
i am looking to drop the car. the car is my wifes....but i always drive when not at work? whats the most recomended i dont wanna go thru tires like crazy.
i hear htech? but do they mean coupe or sedan. ? also does anyone have pics of an htech drop on a sedan?
You've got 153 pages to look through.
I'd start now.
Old Apr 4, 2012 | 10:19 AM
  #2297
JAYRIPPA420's Avatar
lol wow bro real helpful ..? and honeslty i didnt quote you so y respond with a wise remark ? lol any way the crazy **** is that i have been reading the thread.now a helpful sedan owner that is for the g35 community whats ur suggestions??
Old Apr 4, 2012 | 10:29 AM
  #2298
vpV36's Avatar
Originally Posted by GXXXV X
its pretty simple to do the extenders if you install them at the same time as the coils...put them in as one peice, but basically:
1- remove rear seat bottom, pulling on the two white tabs under the middle part of each seat
2- unscrew the bottom part of the seat backs, you should now be able to slide them up and out, you will understand how they go back in when you see the back of them it just hooks on
3- you should now be able to see the sealed off part where the shock housing is... if you want to install without lifting up the car, you will need to drill probably about a 2" hole PERFECTLY in the center...(im not sure how safe this large hole would be due to the 2 built in bolts nearby it but you should be fine). BE VERY CAREFUL when drilling the hole not to let the drill go too deep once it cuts through or else it will harm your shock adjustment ****! i am not sure how much clearance you have between them so either be careful when you do it or just lift the car up and do it.
4- once you have the **** in sight you can now put the extender on and thanks to the large hole you just drilled you should be able to fit the allen wrench in and tighten that **** up
5- when i put my seats back in i left the side of the seats that the extenders are on i left unhooked to give the xtenda some clearance so you can turn it freely... youll understand when you see it
hope this helps a bit
thanks man...appreciate it!
Old Apr 4, 2012 | 02:27 PM
  #2299
BuzzLightYear's Avatar
If I remember correctly anything for the coupe will drop the sedan a extra .5" . With the htechs ure looking at around a 1.4F/.7R drop. With that you prob should be looking into a camber kit. If I was you I'd just save for a set of coils. I wanted to lower my X but wanted adjustability so I bought a set of BC's and I'm only at about 1.5"F/1"R but ride quality is def better then it would be solely on a spring setup. Plus you could always adjust if you plan on swapping wheels....etc. Also with just swapping springs ull prob be replacing ure shocks a lot more often. Here's a thread with a member on htechs and 18"s https://g35driver.com/forums/brakes-...pe-h-tech.html
Old Apr 4, 2012 | 04:10 PM
  #2300
SqueakyClean35x's Avatar
Will bc coilovers for 2007 g35x fit my 2005 g35x???
Old Apr 5, 2012 | 05:25 PM
  #2301
apintojr's Avatar
TBH that was a highley discussed topic in this thread, you could have figured out the answer. But anyway, i had sedan Htech, they got the job done but i really didnt like them. the rear is gonna sit lower then the front and your gonna need rear shocks. the fronts you can do with for a while, you really have no choice unless you want to spend $.
me personally best springs, without mix and matching are the H&R. your still gonna need rear shocks. camber kit you really wont need.
Old Apr 8, 2012 | 01:30 AM
  #2302
i wanna go with coils my question to snoop if he is still on here was how the ride with tein basics were ?im really worried about how comfy the ride will be with my girls in the car ...wife n daughter. whats the smoothest ride with the best drop. H TECH LOOKS LIKE A WASTE .....its a nothin drop and in the end u ruin ur shocks >? lol makes no sense , if ur gunna go out u might as go out knowing u ruined ur oem shocks for something not only u notice but others aswell. any way forget the springs wht coilovers are the best for daily driving
Old Apr 8, 2012 | 01:27 PM
  #2303
apintojr's Avatar
Wow, use the search and read. holy crap. there is only 2 choices. lol WOW, and i say again WOW. do some reading.
Old Apr 9, 2012 | 01:07 PM
  #2304
mcaron's Avatar
If anyone is interested i have a set of almost new AWD BC coilovers for sale, less than 7k miles on them. Visit my profile for the thread in the classifieds or send me a PM
Old Apr 14, 2012 | 05:05 PM
  #2305
MJION's Avatar
About time for me to post...
Thanks to the forum and a BIG thanks to Turtle for helping install the front coils and answering my never ending questions... We had an issue with a rear bolt so I had to finish the job at another friends after I ordered replacement parts...
INFO:
1- Megan Racing
2- Drop Set right above tire. Maybe 3 inches or so
3- Ride is not too bad, was real bouncy at first made adjustments and much better now.
4- No problems really, need rear fender roll and front camber arms. I would recommend anyone who installs coils to get a lifetime alignment package... I have already went twice.
5- 300 miles
6- So far so good
7- 245/40/19 with 20mm spacers
Crappy Cell Phone pics
Before:
After:
Old Apr 15, 2012 | 12:54 AM
  #2306
yosip1115's Avatar
Question update
Changed a few things; lowered the front and got a new rim job lol.
I think I'm gettin there... what do you guys think?
1: G35 C/350z combo+spring mount and other mods
2:`2.25"
3:Great; responsive and sporty while perfectly balanced
4:Could be a bit lower...
5:8k
6:My rear tires wore out before buying the SPC camber/toe kit, the fronts have been fine
7:17x8 wheels; 1/2" spacers coming soon
[IMG][/IMG]
Old Apr 15, 2012 | 08:43 PM
  #2307
TurTLe*'s Avatar
INFO:
1- Megan Racing
5- 300 miles
6- So far so good
Before:
After:
LOOKING GOOD MAN!!!!! After seeing now nice the front was as you drove off, i was very pumped to do mines.
I'm pissed due to work schedule I wont even be able to consider installing my coilovers to mid may.
Old Apr 16, 2012 | 12:21 AM
  #2308
pmd u ***** ... ^^^ yeah sick drop
Old Apr 16, 2012 | 12:47 AM
  #2309
teflon_don's Avatar
Nice Drop Turtle
Here is my drop on Eibach Prokits. not to thrilled about ride quality.
Old Apr 16, 2012 | 07:05 AM
  #2310
TurTLe*'s Avatar
Originally Posted by teflon_don
Nice Drop Turtle
Not my drop, i just helped with the install. But come mid- may when i have the time to take care of mines, it will be just about as low.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
