Calling all "X's" with a lowered suspension!
Old Feb 17, 2016 | 08:01 AM
  #2776
Banikid's Avatar
Originally Posted by Bruce_G35x
That's who I contacted from thmotorsports. He said they didn't have any.
That's weird. These are built to order. When I ordered mine they put in an order to Fortune Auto.
Old Feb 21, 2016 | 02:06 PM
  #2777
drifterxG's Avatar
Some recent pics to share with you guys. Recently changed headlights and tail lights (Sequential chaser LED), and ceramic tint.
Old Feb 21, 2016 | 02:18 PM
  #2778
Banikid's Avatar
Talk about goals lol Your G is beautiful!
Old Feb 21, 2016 | 03:34 PM
  #2779
yosip1115's Avatar
How's she holding up? You up the power yet?
Old Feb 25, 2016 | 10:50 AM
  #2780
adamgx's Avatar
Hey I'm new here
Old Mar 24, 2016 | 03:14 PM
  #2781
Codyh515's Avatar
Coilovers on a 04 x help!!!!!!!!!
Anyone lower a 04 x on coilovers? If so how low? Any problems with axle boots ripping or bushing? I already have the SPC camber arms in the rear along with the provided toe bolts. Any clearance issues with exhaust? Already lowered on the eibach pro kit. The coilovers of interest are the BC BR the awd ones. Also the red emblem insert wasn't my doing. Haha. My dad decided he was going to take it apon himself to do it.
Old Mar 24, 2016 | 03:27 PM
  #2782
drifterxG's Avatar
Hi Cody, I'm not quite sure what the maximum is on lowering G35X before the inner axle boots crack, but for me (2005 G35X)..once I passed 24.25" (measurement from ground to fender), I noticed mine cracked. To give you an idea, that's with the sub-frame almost touching the ground basically which I don't recommend.
From the looks of your pics, it looks like you can still drop the front 1.5" lower without effecting boots. The rear can be pretty low. I've been slammed before without cracking boots. With your setup, I'd just drop it all around until the fender is barely above tire. Sorry, I don't have exact measurements. Once you lower it, I'd get a laser alignment too while you're at it.
Here's pic of mine with 19's with a moderate drop (BC Racing Coilvers)
Hope that helps
Old Mar 26, 2016 | 08:51 PM
  #2783
Banikid's Avatar
26.5 is the sweet spot from what everyone has told me. Im about there and havent had issues. Was a bit lower than that before and I tore my cv boot.
Old Mar 26, 2016 | 08:56 PM
  #2784
Codyh515's Avatar
Hope that helps
Yea that actually helps a lot. But one more question? Well I guess maybe two. How bad was the camber wear? And on the rear coils do you have a separate spring for the rear spring bucket? Or is it a normal spring over shock? From what I see on some places they have both. But I can't find an option for them in one place.
Old Mar 29, 2016 | 03:37 AM
  #2785
Black05X's Avatar
Originally Posted by d3zzy718
350z h&r springs
What year were your h&rs? I am trying to lower my g35x easily and not expensively
Old Mar 29, 2016 | 03:42 AM
  #2786
Black05X's Avatar
Lowering my 05 g35x
I need to lower my 05x but i don't want to spend more then 300.... Can anyone help with that?
Old Mar 29, 2016 | 01:21 PM
  #2787
Black05X's Avatar
Originally Posted by Oggie
Here is my after pics: Attachment 45282Attachment 45283
Please include in your post:
1- 2004.5 350Z Roadster Springs
2- I think 1 to 1 1/2 inches.
3- Suffered a bit but corners much better (flatter)
4- After lowered, the steering wheel is off centered. Pending alignment.
5- About 2000 km on the lowered springs
6- No problems with the shocks. No bottoming.
7- stock OE rims and tires (7 x 17)
Where did you get your springs
Old Mar 29, 2016 | 02:00 PM
  #2788
drifterxG's Avatar
The rear coilovers are separate. BC Racing didn't make it a true coilover design for the rear. The springs reuse bottom rubber pillow mounts if I remember correctly. The height is adjusted from the spring adjuster. I left shock as is.
Camber wear in rear gets noticeable after being lowered more than 1.5" for a while. Camber kit helps a lot to adjust to your liking with alignment.
Old Mar 31, 2016 | 11:21 PM
  #2789
Fire0nic3's Avatar
you have more pics of those headlights? Looks like the eBay ones
They look good though!
Old Apr 1, 2016 | 01:55 AM
  #2790
drifterxG's Avatar
Thanks, I like them too. Haha...and yea, they're the ones off eBay. I'm going to mod them with better shrouds, sequential LED strips and maybe another projector/led halo retrofit for lower lights.
Here's a more recent pic, but with a mockup of my Mirimoto DTRLs :
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
