Calling all "X's" with a lowered suspension!
This is my first set of coils so I'm going to go ahead and say yes. The only reason that comes to mind is that both spindles (if you want to call it that) wont have pressure so it'll be easier to loosen it up and adjust it as opposed to grinding the threads cause of the pressure.
Someone could correct me on this if I'm wrong.
I don't think coils would be ideal to drive in the winter. Anything that's adjustable is always hard to configure. Think about changing your suspension and you had a few or so bolts that were hard to remove. Same thing with the coils except the adjusters would be hard and you might even ruin the threads since they are exposed to the salt and what not.
Just ordered BC coilovers for my '05 X
Got front and rear camber arms too in case I want to go lower than 1-1.5"
Do I need my rear fenders rolled if I'm running coupe 19s with 245/40/19 tires?
Also, those who have BCs already: When the rears are at max height, how much lower is the car than stock?
2 different sets of springs front and back? I thought you could get it right with the Eibach springs sold for our X's.
