Calling all "X's" with a lowered suspension!
Old Apr 9, 2016 | 03:19 PM
  #2791
dustynhugee's Avatar
I was contemplating on purchasing Pro kits for my 06' X but it seems like the H&R's are a sure bet. That being said does anyone know what the correct part number for the H&R's cause i am ready to purchase ASAP! Thanks in advance yall!
Old Apr 12, 2016 | 10:20 AM
  #2792
reaper76's Avatar
The part number I used to order my H&R springs for my 04x was 53036 should be the same for you as well.Thanks
Love my H&R's btw
Old Apr 12, 2016 | 05:52 PM
  #2793
Hey reaper76 do you by any chance have any pics of your whip, and are you running stock struts or kyb's.....
Old Apr 12, 2016 | 06:09 PM
  #2794
reaper76's Avatar
yes page 184 of this thread. Also I am on stock struts with +40 18 inch wheels with 225/45 tires. I now have 15mm spacers on all 4 corners(not pictured) and it looks a lot better. That said page 184 should give you a good idea.
Old Apr 13, 2016 | 02:52 PM
  #2795
Bet I will take a look bro, believe it or not i just found these springs on Tirerack for the Low!
Old Apr 17, 2016 | 12:32 AM
  #2796
reaper76's Avatar
New wheels
Old Sep 6, 2016 | 03:01 PM
  #2797
giuseppe04's Avatar
Anyone have the ground to fender measurement with h&r springs installed? I have 245/45 18 tires and am wondering if I will be ok to lower it with h&r springs for the sedan, anyone think it will work without rubbing fenders? Thanks
Old Sep 6, 2016 | 03:28 PM
  #2798
reaper76's Avatar
My 04 x is lowered on h&r springs and I have 20's on mine which are 20x8.5 with 235/35 rubber on them with a +15 offset and I have no running issues at even with 4 people in the car. I had 18's on mine when I first lowered but it still had to much wheel gap for me.fender to ground on all 4 corners is 26 inches with the 20's if I remember it 24 1/2 with the 18's and 225/45-18 tires hope this all helps.
Old Sep 8, 2016 | 07:08 AM
  #2799
giuseppe04's Avatar
Thanks
Thanks for the info, I am 27.75 ground to fender right now with coupe springs and 18 inch coupe wheels. Should have h&r installed this weekend and measure then. Would anyone be interested in buying 06 coupe springs with 60k, brand new kyb mounts and oem struts for an x all put together already or would separated be better?
Old Sep 20, 2016 | 12:18 PM
  #2800
eloke's Avatar
Calling all V36 G35X SPORT owners :-)
Im having trouble finding any info on specific G35XS models for lowering springs.
Looking for something mild, but noticeable. The more I read, the more I learn, but also the more I question if anything Im reading will apply directly to the XS model. When I look at a non S 'X' model, they seem a lot higher than my XS model. Any help is appreciated. I dont even mind smart *** answers ;-) Thanks everyone!!!!
Old Sep 21, 2016 | 11:47 AM
  #2801
AJC128's Avatar
07 G35x On Eibach Pro Kit Springs
07 G35x On Eibach Pro Kit, Only dropped it less than 2" maybe about 1.5". I down over 2,000 miles on them half being a trip from Connecticut to South Carolina. Even with luggage smooth ride unless your hitting potholes. Definitely noticeable in handling and slightly in looks.
Old Sep 21, 2016 | 11:52 AM
  #2802
eloke's Avatar
Sport model or standard X?
Old Sep 21, 2016 | 12:26 PM
  #2803
AJC128's Avatar
standard x
Old Sep 22, 2016 | 12:44 AM
  #2804
Infiniti_G35x's Avatar
i have an 04 g35x can some one suggest a quality adjustable suspension kit for under a grand? thanks in advance
Old Sep 22, 2016 | 12:02 PM
  #2805
AJC128's Avatar
Unhappy No Luck For Me
Originally Posted by Infiniti_G35x
i have an 04 g35x can someone suggest a quality adjustable suspension kit for under a grand? thanks in advance
I couldn't find anything I had to go with Eibach Pro Kit and a Bit stiffer shocks and struts. The only really adjustable stuff is going to be around $2,000 unfortunately for the X.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
