Climate Control - Regular vs Econ Setting
Old Jun 14, 2006 | 09:21 AM
mkrzyzek's Avatar
I couldn't find this mentioned by doing a search....
Could someone explain the difference between the "normal" Auto setting and the "Econ" Auto setting? I read the manual but it didn't say too much on it. One point of confusion for me is that when I am in the car on a hot day and I have the regular auto setting on 60 degrees, after the car feels like an icebox it does not kick the fan down to a lower setting, so I have to manually raise the temperature to get the fan speed down, or I have to put the climate control into manual mode and decrease the fan speed myself.
Thanks.
Old Jun 14, 2006 | 09:28 AM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
it should kick the fan down but I too have observed teh smae problem... the air temp sensor downst seem to know when enough is enough
Old Jun 14, 2006 | 09:39 AM
35bills's Avatar
If the setting is at 60F( I'm in Canada= 18C)its at its lowest set point.
In auto mode the fan will not kick down at this temp. You have to raise the temperature setting and you will see the the fan speed decrease.
Remember in your house, if you have A/C, you do not run the temp at its lowest setting . You will be freezing you gonads off!!!
Hope this helps out.
Bill
Old Jun 14, 2006 | 09:43 AM
Foo_G's Avatar
i didnt notice he was running at 60... I keep mine around 75 or so and as you stated if I increase the temp by 1* degree or so it does kick the fan down.
Old Jun 14, 2006 | 09:45 AM
Foo_G's Avatar
i have issue with the recir switching to fresh air any time it pleases. Ihate riding down the road and suddenly getting a chest full of diesel fumes. man that steams me.
Old Jun 14, 2006 | 10:43 AM
sliderg35's Avatar
I don't know about other years but I have an 03.5 and whenever I turn on the climate control, it always goes to outside air regardless of the last settnig it was on before I turned it off. Once set, it will stay that way until I turn it off again.
Old Jun 14, 2006 | 10:53 AM
mkrzyzek's Avatar
I also hate the fact that it defaults to the fresh air option. There a stretch of road on the highway that smells like a landfill (I think there is one right by the road), and whenever I can smell it in the car I get ripped that it wasn't set to recirculate.
Old Jun 14, 2006 | 11:27 AM
Foo_G's Avatar
yeah mine does that too but it will change itself when ever it pleases and I can't figure out why.
I have to drive by a water treatment facility and often get caught with it one fresh, rather not so fresh, setting. WHOA!
Old Jun 14, 2006 | 01:18 PM
jimmyc13's Avatar
I believe that you can only recirculate the air if 1) your AC is on or 2) Defrost is on.....is this why you're goes back to "fresh air"? Are you turning your AC off?
Old Jun 14, 2006 | 01:31 PM
madchef's Avatar
I once did a test of fuel economy, auto vs auto econ....no difference whatsoever that I could see....it's beyond me what it does
Old Jun 14, 2006 | 01:51 PM
Foo_G's Avatar
no sir. I'll have the a/c going riding down the hwy and every so often it just switches over to fresh. I have tried auto manual and dbl chcked to make sure i wasnt just going nuts.
for the moment it is simply an inconvinence but I hope it does not progress into something more probelmatic. It is hard to tell when it is goping to happen so I havent bothere going to the dealer about it.
thnaks
Old Jun 14, 2006 | 02:38 PM
DieselX's Avatar
hahaha
Old Jun 14, 2006 | 02:43 PM
Foo_G's Avatar
Originally Posted by DieselX
hahaha
man it stinks so bad you can taste it
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Team STILLEN
Aug 10, 2015 08:17 PM
itschuckster
Jul 25, 2015 08:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
