350z springs
Old Jun 14, 2006 | 09:24 PM
dyenboy's Avatar
Registered
350z springs
hey..so my installed 03 springs and seems that it raised up abit about ..was 1 1/2 fingers, now 2 fingers..is it possible to cut the springs or should i get some lowering springs?
Old Jun 14, 2006 | 09:26 PM
KrazyEd's Avatar
Thats wierd...the 350z springs should lower the sedan. As far as cutting, I highly recommend not doing it.
Old Jun 15, 2006 | 12:24 AM
Tunerz_Store's Avatar
Give the suspension some time to settle. DON'T EVER CUT SPRINGS
Old Jun 15, 2006 | 12:46 AM
vodkarocket's Avatar
Modded Member
I agree don't ever cut the springs, but the suspension was previously on a Z and I'm sure it's had a chance to settle already.
Old Jun 15, 2006 | 12:52 AM
It hasn't had a chance to settle on his car though. I waited for about 2 weeks before I got an alignment. I also noticed more of a drop after a few days as well. My springs were used as well. Go jack your car up, then drop it back down. Tell me it doesn't sit higher until you move it from that position.
Old Jun 15, 2006 | 01:05 AM
Modded Member
He has had his springs on for over a week.
Old Jun 15, 2006 | 01:11 AM
Maybe they aren't Z springs. It's not possible to put a shorter spring on and the car set higher. AFter a week, it should have been noticeable.
Old Jun 15, 2006 | 01:15 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
DON'T CUT! Use a Welding Torch to SAAAAGGGGGGG!! No Really Go with Some Proven lowering springs.......
Old Jun 15, 2006 | 02:18 AM
ttrank's Avatar
Grocery getter
Was this right after you put them on. They will settle once the suspension moves a little. If it does not go down, they are not 350Z springs. I would not cut any spring for your G unless it is a non-progressive.
Old Jun 15, 2006 | 03:14 AM
FenixL1P's Avatar
dude, you got hosed on your springs.... it is a possibility they aren't 350z springs....
after putting one week old '05 350z springs on my 6mt, wheel gap went front 4 finger gap to 2 finger gap immediately after removing the jacks...
Old Jun 15, 2006 | 11:08 AM
dyenboy's Avatar
Registered
these are 350z springs..they definetly dropped, was at 5 to 1 1/2 fingers..rear was 5 to 2 fingers...got an alignment right after..
I just notice the other day that, I can fit 2 fingers under the rear..so it has risen 1/2 finger up..and the front as well..
I thought it would settle lower, but instead it actually went higher, which was wierd..so I was wondering if anyone else had that same situation?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
