Rims
Old Jun 19, 2006 | 04:07 PM
BuckeyeG's Avatar
Rims
Hey will 19x8.5" (20mm offset) and 19x9.5 (30mm offset) fit and look ok on my sedan i guess these came off a coupe but I think they will be ok but just wondering from some of you wheel gurus. I want them to come out to the edge ofthe fender and no im not droppped yet.
Old Jun 19, 2006 | 04:13 PM
LuXXXz's Avatar
no i dont think either will actually work
but you have the ask the man
CHICO
Old Jun 19, 2006 | 04:39 PM
skeleton_cru's Avatar
Sedan
NO WAY. You will rub the fenders.
Old Jun 19, 2006 | 04:44 PM
sliderg35's Avatar
You need +35 to 38 front and +45 to 48 rear
Old Jun 19, 2006 | 04:55 PM
sweettalker's Avatar
Not necessarily. I have +35s all around with 8.5 in the front and 9.5 in the rear with no rubbing what so ever. Just use skinner (but make sure you calculate the correct ratio corresponding to the stock size) tires. That's what I'm doing with no problems
Old Jun 19, 2006 | 05:10 PM
Sedan
You have 9.5, +35 in the rear and no rubbing? You must not be lowered, right? When you look straight down your rear fender I bet you can see the tire sticking out passed the fender a bit.
Old Jun 19, 2006 | 05:13 PM
BuckeyeG's Avatar
Ok so just so i got this straight the small the spacer the bigger it is?
Old Jun 19, 2006 | 05:33 PM
Sedan
I'm not sure what you're asking, but the smaller the offset number the more the wheel is pushed out towards the fender. The larger the offset number the more the wheel is pushed in towards the suspension.
Old Jun 19, 2006 | 07:47 PM
ttrank's Avatar
Grocery getter
I can see a 9.5" with +38 working. I have a 10" +43 and it does not stick out at all. It tucks with the fender rolled.
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
