Nismo Shifter Feedback
Old Jul 10, 2006 | 01:18 PM
chobble19's Avatar
Lightbulb Nismo Shifter Feedback
hey everybody just another monday here....thought i'd ask for some input! i recently had a nismo shifter installed in my 05 sedan at the dealer and besides it feeling a bit more "knochy" (if thats how u spell it) i got some sort of grinding noise a couple days after the install....it seemed to be coming from the lower part of the shifter i guess where it screws on or whateva. the noise was noticably loud and happened when i would deccelerate in gear or in neutral, i no longer have the problem for some reason but im still a little concerned about it! has anyone had or know anyone with this problem??? cars going to the dealer friday......
Old Jul 10, 2006 | 07:20 PM
ttrank's Avatar
Grocery getter
Is this a short shift kit or just a ****?
I was not aware Nismo made a kit.
Old Aug 15, 2006 | 12:45 AM
chobble19's Avatar
Exclamation
buMMP for knowledge!
Old Aug 15, 2006 | 03:51 AM
ttrank's Avatar
Grocery getter
Same question...
If it is just the **** it sounds like they did not clamp the lower part when taking off the old ****. It it is a new shifter then they might have not gotten the sleeve back on correctly.
I have a nismo titanium **** and a rogue engineering shifter both of which I installed myself. It is easy to mess it up. It also could be the synchros going out. Had my tranny replaced once under warranty for that (as have hundreds, maybe thousands of other G's/Z's).
Old Aug 15, 2006 | 10:37 AM
chobble19's Avatar
Post
synchros?? i still getta lil gurguling from my shifter in gear usually around turns...i was riding around last night with the radio off checking for tranny noises and all seems well.....i've been having some dreams about 3rd shifting funny though
chobble19's Avatar
Post
adjustable....short shift kit
Old Aug 15, 2006 | 10:50 PM
StarChamp's Avatar
I have a B&M short shifter, and it definitely narrowed the shift gates; you have to be a bit more precise when you throw the stick, but you get used to it. 6th is still a little tricky, but that's never a fast shift anyway.
You shouldn't be getting any type of grinding sensation (huh huh huh) after your shifter install, these tranies use linkages and aren't like the old top-loaders where the stick went right down into the gears. No reason for your installers to have messed with the trans at all. If it is your synchros, the new shifter certainly didn't have anything to do with it, you just might notice it more because the linkage is tighter. Synchros would present more of a problem during actual shifting, anyway, not while you're in gear. If your not still having the problem, I wouldn't worry. If you want to be on the safe side, ramp/jack up your car (use jack-stands, please), position yourself directly underneath the driveshaft where the shifter comes through the floor. There's a boxy rubber boot that protects the lower linkage; pop that cover off and check for metal shavings. If none, you're good; if metal, talk to your installers.
Old Aug 16, 2006 | 01:40 AM
chobble19's Avatar
Talking
haha thanks for the heads ^ star! i will try and get underneath it sometime soon...ive been thiinking of putting ANOTHER list of issues ive been havin to take the car in AGAIN to tha dealer....who installed my shifter sigh
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
