Can it be done?
Old Jul 23, 2006 | 08:01 PM
lowerjam's Avatar
Can it be done?
Axis Penat 20x9 w/+40 all the around w/ 255/35 tires? And if so should should look pretty good hu?
Old Jul 23, 2006 | 08:16 PM
GeeWillikers's Avatar
Walking The Fine Line...
Nice first post..
YAWN..
Did you even bother to look for the right forum?
Old Jul 23, 2006 | 08:26 PM
lowerjam's Avatar
aww geewillikers sorry to offend you
Old Jul 24, 2006 | 01:18 AM
skeleton_cru's Avatar
Sedan
EDITED: The wheel size and offset are fine in the rear. You should go with a narrower wheel in the front, 8.5" max. Use a wheel/tire size calculator to find the right tire size. Get as close to stock tire height as possible.
PS - Don't mind GW, he forgot to take his Midol.
Old Jul 24, 2006 | 10:01 AM
You didn't offend me, I'm just a *****.
Old Jul 24, 2006 | 10:03 AM
UFGatorG35's Avatar
Confucious say "virginity like balloon: one *****, all gone."
Old Jul 24, 2006 | 12:24 PM
jran76's Avatar
I would guess that your fronts will rub on the control arm. You would need a lower offset in the front and they would stick out pretty far then. You really need a 8.5" with around a +38.
Old Jul 24, 2006 | 12:25 PM
az1anbeethoven's Avatar
hahhaha that was a good one
Old Jul 24, 2006 | 09:10 PM
lowerjam's Avatar
thanks guys, from what i could find +35 would be my other option for up front
Old Jul 24, 2006 | 09:33 PM
RetAF's Avatar
I`m with you, Gee. My shrewd, analytical, military mind detects a complete disregard for the wheel and tire forum. Just look at the posts on this forum. Eliminate the wheel and tire stuff, and not much is left. I must have forgotten my Midol, too.
Old Jul 24, 2006 | 10:57 PM
I guess there are hidden benefits to being a ***** after all. LOL!
Old Jul 24, 2006 | 10:58 PM
I use Pamprin, thanks.
Old Jul 24, 2006 | 11:32 PM
Sedan
Good catch, I don't know what I was thinking. A nine inch wide wheel in the front will probably rub either the control arm or the fender depending on what offset you get. Better to go with 8.5" in the front.
Old Jul 25, 2006 | 12:47 AM
Sedan
I'm usually the same way, but I took pity on this guys poor newbie soul and tried to answer his question.
