Difference was NIGHT and DAY!!!
Old Aug 16, 2006 | 10:21 AM
chobble19's Avatar
Talking
Originally Posted by sjc1789
i just cleaned my injen filter yesterday... took bout an hour to take off clean an put back on.... my ride feels smoother now but not a big jump... ill look into the cleaner for the MAF
what'd ya clean that injen filter with? were u able to remove it through wheel well? i think it's abou that time for me
Old Aug 16, 2006 | 10:28 AM
chobble19's Avatar
Question
....where the helllz can i get an MAF cleaner and intake cleaner....i would doubt discount auto parts would have it?
Old Aug 16, 2006 | 11:04 AM
vodkarocket's Avatar
Modded Member
Originally Posted by scorcher76
The easiest way to describe it was before cleaning the MAF, acceleration didn't felt linear, especially from a stop...as if something is holding it back from going faster...then as the RPM rises then you feel the surge of power and the car advances. In fact, when accelerating from a stop, i kinda feel hesitation for half a second, then a jolt and the car advances...
Alex
YES! That is exactly what is wrong with my car. You don't have any idea how happy I am right now, I thought I had a serious and expensive issue to deal with on my car.
I owe you a beer. Please PM me your PayPal address.
Old Aug 16, 2006 | 11:35 AM
realgone's Avatar
Widdle ya into kindling
Good Info.
Old Aug 16, 2006 | 11:49 AM
Neal376's Avatar
I'm getting a amsoil "nanofiber" (no-oil, reusable) universal filter for my stillen intake.
When I am exchanging filters, I will clean the MAF as well.
which side of the MAF do you clean?
Old Aug 16, 2006 | 12:37 PM
r15k's Avatar
Ive felt a jump in my car aswell. Could it be that my intake is dirty or has the same problem with the MAF sensor? When I wash my car or when the car has been sitting for a while and i start it up and touch the gas pedal to give it a little go it feels like its losing power then it jumps then acts normal.
MAF sensor then right? or dirty intake? I also have an '03
Old Aug 16, 2006 | 12:39 PM
scorcher76's Avatar
e-fan conversion?
Originally Posted by andycon
Man, oh man - now u got me excited - for some time I have been really concerned about the sluggish bottom-end, and I have been searching for answers - sounds exactly what u are describing - What I am experiencing is (relatively) sluggish take-off up to about 3,000rpm, then it really kicks-in over 3000. In colder weather, it is much better, until the car warms up, then it bogs down.
I had a suspicion the MAF may be affected, now you have provided some indications that it may be - especially, as you say, on the earlier models (I have 03 too).
I got a dynapack dyno recently at SGP (a crappy dyno), it indicates screwed-up A/F ratio. The dyno is crappy because they dyno'd in 4th and it kicks back to 3rd. (am getting a re-do for free). When you dyno the 03's it needs to be done in 3rd (ramp-up to 3600), then power on. However, the A/F is around 14 until 3500rpm, then it drops to 13 thru the run FWIW, peak HP was only 230, but I was more interested in setting a baseline and looking at the A/F.
Anyway, in addition, I got a loaner car the other day while they did the AC TSB replacement - the loaner was an 05 5AT, and for comparison sake I tried a few standing starts - I could get the loaner to easily break loose from a mild brake-launch, whereas it is hard to get mine to spin. (although I do have better/wider tires (245/45/18)). It also felt zippier thru about 4500rpm, then I think my top-end was stronger (azz-dyno).
I will report back this afternoon after a MAF cleaning.... hoooo looking forward to this one....
FWIW; have you considered an e-fan conversion? I felt that was very worthwhile.
What is an e-fan conversion what what does it do?
Alex
Old Aug 16, 2006 | 12:40 PM
scorcher76's Avatar
Originally Posted by r15k
iVE FELT A JUMP IN MY CAR ASWELL COULD IT BE THAT MY INTAKE IS DIRTY OR THE SAME PROBLEM WITH THE MAF SENSOR? WHEN i WASH MY CAR OR EVEN AT STOPS AND i TURN ON THE CAR AND TOUCH THE GAS PEDAL TO GIVE IT A LIL GO IT FEEL LIKE ITS LOSING POWER THEN IT JUMPS THEN ACTS NORMAL...
MAF SENSOR THEN RIGHT?
Same problem here...try cleaning your MAF.
Alex
Old Aug 16, 2006 | 12:43 PM
scorcher76's Avatar
There way I cleaned it without having to dismantle too many pieces is the following:
1. Dismantle your Z-TUBE or G-TUBE.
2. Uncrew the bracking holding the MAF housing. Inside the housing, you will see a grill. I simply cover that grill with a towel and basically spray the cleaner from the other side of the housing tube directly onto the MAF sensors.
3. Enjoy your new performance!
P.S. I didn't need to dismantle the MAF itself from the housing.
Alex
chobble19's Avatar
Post
Alex
electric fan conversion....not an expert but im guessing it makes things cooler
r15k's Avatar
wow, thought i was the only one experiencing this..cool glad to know im not the only one..
Old Aug 16, 2006 | 12:44 PM
scorcher76's Avatar
hehe Thanks! Hmmm, maybe you have an idea how to replace brakes pads? heheh
Alex
chobble19's Avatar
Question
yea double post but.....where can i get the cleaner for my MAF and air filter?
Old Aug 16, 2006 | 12:46 PM
  #30
jimmyc13's Avatar
Please do! How many miles do you have on your '03? If you report back with noticeable gains...off the the autoparts store I am!
