Difference was NIGHT and DAY!!!
Old Aug 16, 2006 | 04:37 PM
  #46
BigSash's Avatar
so you disconnected the maf from both sides, (the filter and the z-tube) and then held the towel behind one end and sprayed through the filter?
^ is this correct?
Why did you hold the towel at the other end? to catch overspray or to see what you were spraying off? THX
Old Aug 16, 2006 | 04:44 PM
  #47
driguez's Avatar
so anyone else done this??
Old Aug 16, 2006 | 04:47 PM
  #48
nuttyprof's Avatar
^ is this correct?
He cleaned the MAF sensor (that little strip of metal in the 2-3 inch plastic tube). Not the filter (which is the big regtangular thing in the box).
I think you know this, but your wording is confusing, so I'm clearing it up for anyone who hasnt opened up their intake before.
On another note, THANKS!! this really helped.
  #49
scorcher76's Avatar
^ is this correct?
You're right except for the last part. I removed the Z-TUBE and the MAF box housing by unscrewing one screw on the right that holds the box in place. You don't really need to remove the filter but I did it anyways because once the MAF box was removed, my filter was gonna fall.
Yes, to catch overspray instead of having the cleaner sprayed all over my engine compartment. Again, I held the MAF housing up, covered the grilled end and sprayed on the other side.
Ideally, one can even remove the 4 screws holding the plate where the MAF is installed so you clearly see the MAF sensors. Guess I was too lazy for that...
The whole procedure took 15 minutes max.
Alex
Old Aug 16, 2006 | 06:04 PM
  #50
MyRedG03.5's Avatar
Originally Posted by vodkarocket
Any idea where I can find the CRC here locally?
Kragen ~$6
Old Aug 16, 2006 | 06:42 PM
  #51
DaveB's Avatar
Originally Posted by andycon
Man, oh man - now u got me excited - for some time I have been really concerned about the sluggish bottom-end, and I have been searching for answers - sounds exactly what u are describing - What I am experiencing is (relatively) sluggish take-off up to about 3,000rpm, then it really kicks-in over 3000. In colder weather, it is much better, until the car warms up, then it bogs down.
This is something all 5ATs tend to do. The reason why the car feels better in the colder weather is because the air is denser with oxygen.
I had a suspicion the MAF may be affected, now you have provided some indications that it may be - especially, as you say, on the earlier models (I have 03 too).
I got a dynapack dyno recently at SGP (a crappy dyno), it indicates screwed-up A/F ratio. The dyno is crappy because they dyno'd in 4th and it kicks back to 3rd. (am getting a re-do for free). When you dyno the 03's it needs to be done in 3rd (ramp-up to 3600), then power on. However, the A/F is around 14 until 3500rpm, then it drops to 13 thru the run FWIW, peak HP was only 230, but I was more interested in setting a baseline and looking at the A/F.
There's nothing wrong with your MAF and your A/F ratio is fine. The A/F should start at 15:1-14:1 and steadily fall has the rpms rise. The ideal A/F above 5000rpms is in the 13:1 range.
Anyway, in addition, I got a loaner car the other day while they did the AC TSB replacement - the loaner was an 05 5AT, and for comparison sake I tried a few standing starts - I could get the loaner to easily break loose from a mild brake-launch, whereas it is hard to get mine to spin. (although I do have better/wider tires (245/45/18)). It also felt zippier thru about 4500rpm, then I think my top-end was stronger (azz-dyno).
I will report back this afternoon after a MAF cleaning.... hoooo looking forward to this one....
The reason why the loaner felt so good is because it has the stock intake and most likely the smaller 17s. Like I've said all along, aftermarket intakes hurt low rpm throttle response. I recently did an experiment with my stock intake box. I yanked the Power Duct and the over radiator duct, basically increasing the intake volume of the stock intake by about 60%. The intake was deafening, but low rpm throttle response went in the tank. With the ducts in place, the car feels much stronger under initial launch, often times spinning the tires for 10' in hot weather. With this revised intake setup, the car would barely chirp a tire and the initial bog was worse. I put the ducts back on and everything was back to normal. The most significant thing I noticed without the ducts in place was the lack of surge in power as the car upshifted under normal throttle. It's hard to explain, but when the ducts are in place, there is a wave of power on each successive upshift.
BTW, the 18s are hurting your initial launch too.
Old Aug 16, 2006 | 07:22 PM
  #52
ttrank's Avatar
Grocery getter
I just went to NAPA auto parts and they told me that they are getting in a big CRC display and will have it tomorrow.
Old Aug 16, 2006 | 07:40 PM
  #53
boe's Avatar
boe
subscribed
Old Aug 16, 2006 | 08:16 PM
  #54
codeflux's Avatar
oooooooooooo i'm'a doin' tis! hehe. this is *way* better than sitting at work. i'm gonna head out to local NAPA and/or Kragen and check this shyte out.
Old Aug 16, 2006 | 08:44 PM
  #55
gtbigup01's Avatar
Good response, it's funny you'd post this because in my opinion, regardless to what others may think, but I doubt aftermarket engineers of intakes know more about the G35 than the engineeers of the G35, thus don't expect too many aftermarket parts to outperform the stock, unless we're talking about turbos/superchargers. I know everyone will start to flame but hey you know it's true.
Old Aug 16, 2006 | 08:47 PM
  #56
DieselX's Avatar
^^ umm, what about emission tests and inspections. Thay have limits/standards to abide.
Old Aug 16, 2006 | 09:14 PM
  #57
codeflux's Avatar
$5.99 at Kragen. of course, i ended up spending $50 more on other crap i may or may not need. will do this thing tonight.
Old Aug 16, 2006 | 10:03 PM
  #58
G35_TX's Avatar
And where is "YOUR" data regarding this. I mean your saying it hurts, but where is your test results (YOURS)? And did you actually measure it to be 60%?
Intakes work with the correct setup. EOD.
Old Aug 17, 2006 | 12:20 AM
  #60
DaveB's Avatar
A flexible measuring tape and a calculator go a long way.
Intakes are great noise makers and for some, a nice piece of eye candy. EOD.
