oem 18 wheels+tire combo
Old Aug 21, 2006 | 06:36 PM
G SEDAN's Avatar
Getting the 05+ 18" sport wheels real soon. I am assuming they are 18x8s all around? What tire size set up would you recommend on the rims. I was thinking 245/45/18 rear and 235/45/18 in the front. Is there an advantage in handling on stagger tire set up. Also would it be good just to go 245/45/18 on all 4? I have z springs sitting in the garage so that will definitely be a plan in the near future. Sorry guys, I tried searching and all it comes up with are "18 year old sedan drivers" and not "18 inch sedan rims" LOL
Old Aug 21, 2006 | 07:16 PM
(>")> G35's Avatar
The sport wheels are 18"x7.5" and the OEM tire size is 235/45/18. I wouldn't do the 255/45/18 and 235/45/18 setup, it's next to impossible to maintain the same diameter in the front and rears. I would just go with one size all around.
*EDIT*
Opps, i read the wrong numbers. But as for you posted setup, it would work, but at the same time you can just put 245/45/18 on all fours since your running the same size rim.
Old Aug 21, 2006 | 07:17 PM
ironpirate's Avatar
i got 235 all around, i dont think stagger looks good
G SEDAN's Avatar
how about 245x45x18 all around then?
Old Aug 21, 2006 | 07:18 PM
absolutg's Avatar
workin...
i think those are too wide for 7.5" wheels
Old Aug 21, 2006 | 07:39 PM
G SEDAN's Avatar
iron pirate or anyone else with stock 18 rim and tire willing to take a picture of their car from behind where tire width is very visible so I can see how wide they look from behind?
Old Aug 22, 2006 | 10:23 AM
da mayor's Avatar
ill take a pic later but tires dont look that wide with 235/45/18" tires
Old Aug 22, 2006 | 04:02 PM
mikeee2's Avatar
Here you go. The Avon 245's fit into the 7.5 rims fine, don't worry about it. However, if you plan to lower it with z springs, you should go with 245/40/18 or 235/45/18. 245/45 profile is a bit taller and wider than oem. I went with 45 series to close the fender gap. Then my car was dropped with z springs afterward and there was barely any gap in the rear (possibly rubbing). Go with 245/45 if you don't plan to drop it but if you do go with 235/45 or 245/40 (in my opinion).
https://g35driver.com/forums/attachm...2&d=1139719222
https://g35driver.com/forums/attachm...3&d=1139719222
Old Aug 22, 2006 | 09:21 PM
wilboytsk's Avatar
Found these on CL san diego...245/40/18s
http://sandiego.craigslist.org/pts/196349923.html
Old Aug 22, 2006 | 10:10 PM
Grumpy_G's Avatar
This was taken right after the unrevised z_spring install, please excuse the quality.
Not directly behind, but enough to show the wheel-to-fender clearance. I personally wouldn't do the 245/45, but 245/40 instead. Both is still within the 3%, but the less sidewall will sharpen up your handling a little more. That and 245/40 is more common size = more tire option. Stock Turanza for now. but looking forward to RE-01R or ADVAN sport for replacement.
If you're worry about the look of the width from behind, then go aftermarket wheel w/275s.
Old Aug 22, 2006 | 10:19 PM
Texasscout's Avatar
That's what I have and it looks meaty!
Old Aug 22, 2006 | 11:13 PM
G SEDAN's Avatar
sorry to announce, althought that craiglist listing was a super duper deal, i contacted the seller wanting to buy and it has been sold..:'( The deal was just too good to pass up for people i guess.
Old Aug 23, 2006 | 01:27 AM
DaveB's Avatar
It's so frustrating because I want a set of 18X8 rims for my car, but the tire choices are just too damn confusing especially considering that I need all season tires. The rims I want are at the Tirerack, but they recommend a 225/45R18 which is 25.9" tall on a 7.5" wide rim. Seeing that the OEM diameter is 26.3" and the rims I want are 18s, that means that 25.9" diameter will be pulled down to 25.7-25.8". I don't want to increase the gaps because I like that way the car looks with the z/coupe springs. The 245/45R18s seems like the logical choice, but now people say there are rubbing issues. 245/40s seem like an option, but after speaking to Trey, he said his 245/40R18s look like crap because the gaps increased quite a bit. A 235/45 is the ideal setup, but of course only crappy RS-As are offered and nothing else.
Old Aug 23, 2006 | 01:42 AM
G SEDAN's Avatar
im going with 245/45/18 with either a z drop or coupe drop...i like the beefy tire look and also ride comfort is more important to me than handling...
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
erich2780
Sep 3, 2015 03:23 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
