Jack
Old Aug 22, 2006 | 07:26 PM
LILShiraz's Avatar
Jack
ok, so i got new rims and i wanted to at least try and out them on myself, but it didnt happen, it took me like 20 minutes to figure out how to take the jack out, and it took me longer and i still cant figure out how to put it back...help please, i have a 2003
Old Aug 22, 2006 | 07:30 PM
RXM's Avatar
RXM
Its fairly easy. Just make sure the jack is lowered to the lowest possible setting by turning the "****" at the end of the jack. Slide the jack into the spot in the trunk that it goes and then turn the **** of the jack to raise the jack a little so that it stays in the compartment. Its that simple.
Old Aug 22, 2006 | 07:49 PM
ttrank's Avatar
Grocery getter
Yep that's it...
Old Aug 22, 2006 | 07:53 PM
anDross's Avatar
word.. yea that's about what you gotta do.. in case you're lowered you might need to put ramps.. if no ramps are available.. then you can use wooden blocks.. and drive up those so you can place the jack easily underneath.
Neal376's Avatar
a even better idea would be to buy a 2 1/2 ton hydrolic jack for about 30-50 bucks.
makes life easier and easier life=safer life.
I put a nasty ding in my car jacking it up with the stock jack (the handle slipped out of my hand)
Old Aug 22, 2006 | 08:26 PM
sjc1789's Avatar
Florida G35 Club
i got a 2 ton jack... so convienient... does the G with ease and leaned my tahoe on one side without a problem
Old Aug 23, 2006 | 09:12 AM
darnelled's Avatar
I had the same problem last weekend. I needed a flashlight to help get it back in, then I needed to turn the **** a little, opening it, and thus wedging it firmly against its surroundings.
Old Aug 23, 2006 | 02:40 PM
shodog's Avatar
The oem jack is a piece of $hit. Make sure when you use it that you chock the wheels. The car can easily roll off the jack.
Old Aug 23, 2006 | 02:42 PM
cato's Avatar
SouthernComfort Moderator
The OEM jack is for emergency use only. Get a good floor jack and you will never use the jack hidden in the trunk.
Old Aug 23, 2006 | 04:34 PM
ttrank's Avatar
Grocery getter
That should be the first thing you buy for your garage. Pick one up along with the beer. The stock jack is such a pain to use. If I had to use it I might not even change my own oil...
Old Aug 23, 2006 | 06:22 PM
jimNC's Avatar
+1, both for the floor jack and the beer
Wait for a sale at Sears, you can get a decent 2.25-ton floor jack for under $30 - look hard enough and you can get the same jack with 2 stands for that price.
I got 2 of these jacks, one to jack at a side jack point and one to then jack the center point to get both wheels off the ground. Cheapest way to get this accomplished, and it is not as much of a pain as you might think. Anyway, I just keep one of these jacks in the trunk as it does not take up much space. One of the jacks I got came with a plastic case, so it stays put ok.
Old Aug 24, 2006 | 01:45 AM
skeleton_cru's Avatar
Sedan
+1000
Old Aug 24, 2006 | 08:18 AM
lelg35's Avatar
There's a jack in the trunk??? Seriously, get a good hydraulic floor jack...don't risk yourself and your car by putting it on the stock jack. Like cato said, the stock jack is for emergencies when you're out on the road and get a flat or something. On a side note, if you do get a floor jack, it doesn't quite fit perfectly. You might need to get an adapter for the floor jack if you don't want to bend the metal on the jack point of the car.
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
TNRocker
Sep 21, 2015 08:36 AM
toadfire
Sep 21, 2015 07:15 AM
