I did a bonehead move on my brakes!
Old Aug 29, 2006 | 08:45 AM
EAndrews's Avatar
So the other day I picked up the car from the shop where he was doing some wire tracing on the HU. After 6 hrs and pulling that draining piece of ****, i was just glad to have my ride back.
I pull off and realize I left my EBrake on for about a 1/4 mile. Now my brakes sound like ****, not a scrapping sound but almost a warped clicking sound. Think I need to have the rotors turned because of this mistake or did I do some major damage to the braking system?
Thanks for any suggestions in advance,
Eric
Old Aug 29, 2006 | 07:40 PM
ttrank's Avatar
Grocery getter
Let them go for a day or two to see if it goes away.
The e-brake is not related to the rotors like you think. It is a drum inside that holds the inner part of the rotor. So turning the rotors would not help this.
If it doesn't go away you will need to take it to a brake shop and see what they can do for you.
Old Aug 30, 2006 | 08:03 AM
EAndrews's Avatar
hmmmm, i didn't realize that for the emerg. brake. yep, might have to run it back for him to check it out. Only other thing is that my brakes might need a good doing, have to get the wheels off to tell though. I might just upgrade all four if that's the case. Thanks for the info anyways..
Old Aug 30, 2006 | 08:56 AM
cato's Avatar
SouthernComfort Moderator
The e-brake is a drum brake on both of the rear wheels. They have nothing to do with the rotors.
Old Aug 30, 2006 | 10:14 AM
EAndrews's Avatar
Yea, i think I just need some new pads and maybe turn the rotors...
Old Aug 30, 2006 | 02:08 PM
ttrank's Avatar
Grocery getter
Yes the problem could still be with your rotors or pads, just not caused by the e-brake situation.
Old Sep 11, 2006 | 05:58 PM
super6's Avatar
ull be fine, i driven i a freinds car for like 3 miles with it up and no problems.
Old Sep 11, 2006 | 07:01 PM
nuttyprof's Avatar
hmm, i pull on my ebrake all the time when i see cops... i didnt have a problem...
but now, my brake, vdc off, and slip lights are on...maybe thats related. hahahahaa..
Old Sep 11, 2006 | 10:16 PM
filanj's Avatar
id suggest having your tires rotated..
Old Oct 13, 2006 | 02:20 PM
EAndrews's Avatar
Actually its not ok.... The heat from the brake warped a rotor on the RR and one on the LR. I'm gonna pick up a new set and upgrade.
Old Oct 13, 2006 | 03:25 PM
falconey's Avatar
Are you sure the brakes weren't already warped. It just doesn't make sense that an ebrake being left up would be the cause of warped rotors.
Old Oct 17, 2006 | 09:03 AM
EAndrews's Avatar
No, not certain but hopefully the new rotors will take care of it.... They aren't bad enough that they are shaking just have a squeeky, scratch sound under braking under 50 mph...
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
pasjr1972
Sep 1, 2015 10:17 PM
