e-fan conversion - dyno results!
Old Sep 8, 2006 | 02:41 PM
  #76
trey's wife's Avatar
My horns hold up my halo
Originally Posted by Jeff92se
I think that's way he suggests using a relay to switch on the fans. You run the actual power to the battery, using the right sized wire and fuse. Then use a termo switch or maybe the oem ecu signal to trigger the relay to turn on/off the fan(s)
LOL I'll take his word for it because I have no clue. I mainly wanted to address the difference for those who do know (including audiblemayhem) to give a better idea on what works and what doesn't.
Old Sep 8, 2006 | 04:21 PM
  #77
G35Luv's Avatar
Originally Posted by trey's wife
Ok I said I would search for you and now that I am not babysitting I did A search. I will say that I suck at picking the right terms to use in a search (it does matter after all) but this thread should give you a good bit if you wade through it.
https://g35driver.com/forums/showthr...onversion+cost
THANKS!!!
Old Sep 8, 2006 | 05:23 PM
  #78
DaveB's Avatar
What the hell? You stole the link I put in post #46
Old Sep 8, 2006 | 09:35 PM
  #79
^^^Sorry. I just told him I would do a search for him so I did. Honestly I was just trying to do it somewhat quickly and not forget (which is what I would usually do)
Old Sep 8, 2006 | 11:09 PM
  #81
DaveB's Avatar
I kid. I kid.
Old Sep 8, 2006 | 11:10 PM
  #82
Originally Posted by DaveB
I kid. I kid.
I know! I just thought I should give *some* explanation instead of just looking silly.
Old Sep 10, 2006 | 03:22 AM
  #83
OCG35's Avatar
Originally Posted by G35_TX
Well, thats his way of telling you flat out he doesn't want to help you probably because of some of the stuff you have said in the past.
^^^ +1000000000
Frankly I'm surprised he helped at all... I wouldn't blame him for saying F'off! But DaveO is always willing to give an informed opinion - he will only explain if you are willing to understand and listen.
In this case "do it or don't" is pretty gracious. {side note - I wonder if DaveO knew this stupid thread would come up when DaveB asked his rhetoric question?}
Old Sep 10, 2006 | 03:30 AM
  #84
OCG35's Avatar
Well, I'd love to add more power to my car especially with something as easy as a fan conversion. DaveO touted this mod as a power gaining mod yet he has no legit data to support his claims. If someone did a dyno and it clearly showed a worthwhile gain (elevated power curve by 5whp+), then I'd probably consider it. But when someone says mod "X" works simply based on principle and technical background, but without any dyno data, it's very hard to accept. I guess I've just been burned WAY too many times by buying into accepted internet claims.
Would you not want a power mod to actually add power? Would you not want proof?
This is total BS because no matter how much dyno data was posted you would go on and on about how the dyno results were flawed or bogus (in fact you already have HERE!)... Geez DaveB can’t you give this a rest?.... You debate EVERYTHING!!!!!
If this was a forum about the first moon walk you would tout a bunch a **** about how it was in a studio and not in space and where's the proof... if this was about a tree falling in a forest you would go on and on about no one was around to hear the sound so where’s the proof... Damn man drive your phucking car and leave the rest alone!
Old Sep 10, 2006 | 03:35 AM
  #85
OCG35's Avatar
Ummm....that's what I was alluding to. A pulley still remains and will still cause accessory drag.
Are you indicating the 2003 mechanical fan was attached to an accessory pulley???... Hmmm weird
Old Sep 10, 2006 | 03:43 AM
  #86
OCG35's Avatar
I think the advantage was overall cost and parts bin sharing. we'll never know the real reason why Nissan did what they did.
I know this much - The Infiniti division of Nissan wasn’t pinching pennies for a damn fan. They put a phucking tampon in my car I don't think they cut corners in the engine compartment to accommodate frivolous **** like that (amoung other things).
Old Sep 10, 2006 | 03:51 AM
  #87
OCG35's Avatar
Originally Posted by trey.hutcheson
Yeah, on the dyno. I obviously don't have direct experience; I'm merely repeating from an imperfect recall.
It's my understanding that Type I autoboxes work a bit differently, and *some* have exhibited odd behaviors with the torque converter on dynos. It's not uncommon for anything below 4000rpms to be invalid. And I think that's also the cause for the looping artifacts displayed in andy's plots.
true... I have a 274TQ spike on one of my dynos in low RPM (well below 4K though)
Old Sep 10, 2006 | 03:55 AM
  #88
OCG35's Avatar
That was a general statement. Whether or not you feel guilty of that action is between you and the guy in the mirror.
This should be posted in about 100 dozen threads... (search DaveB for the ones I'm talking about).
Old Sep 10, 2006 | 01:39 PM
  #89
DaveB's Avatar
Ummm...the mechancial fan is attacted to a pulley which is then driven by the accessory belt, hence the definition of accessory pulley Need I post a picture? Do you know the difference between an accessory belt and timing belt
Old Sep 11, 2006 | 01:07 PM
  #90
Jeff92se's Avatar
Red Card Crew
Invalid argument. He has a motodyne spacer installed.
