Have An Idea For Us X Users
Old Sep 7, 2006 | 01:17 PM
apintojr's Avatar
ok, well i have tein h tech. now all us x owners know nothing out there for us. now like a mentioned before, when i have 2 people in the back or a loaded trunk, or god forbid both, that back of the car dropps like a bitch and it bounces all over the place. now i was thinking of just swapping out the rear tein springs and putting the rear stocks on but leaving the front on teins. would this b a big issue?
Old Sep 7, 2006 | 02:10 PM
da mayor's Avatar
i wouldn't advise doing that because it's a different spring race from the OEM springs and aftermarket.
Old Sep 7, 2006 | 02:51 PM
apintojr's Avatar
understand that. but us x users have no choice but to use stock shocks. and the rear shocks cant handle the load. so putting the stock springs back on to stock form.
Old Sep 7, 2006 | 06:41 PM
KrazyEd's Avatar
You can swap out your rear shocks for the ones that fit the RWD Sedan, Coupe or 350z. THe front shocks are the ones that you cant because they are different.
Old Sep 7, 2006 | 07:50 PM
apintojr's Avatar
ok. now lets say i buy a coilover setup for the RWD 35 the rear setup should still fit then right? anyone ever try this before? i willing to try it just to see if it helps. i love the look of the tien h tech but when 2 or more are in the back =/
Old Sep 7, 2006 | 09:32 PM
bigwilly's Avatar
Yeah too bad we can't just buy rear shocks seperate from the fronts. Does anyone know if there is there a way to modify a set of aftermarket shocks so that the front can mount properly? Someone needs to create shocks for the X.
Old Sep 8, 2006 | 08:09 AM
rayron's Avatar
you can buy koni's for the rear seperately. they are a bit expensive $400-500 but are good shocks with a lifetime warranty... i believe. if the fronts are really an issue for you, you can send your stock front struts to koni and have them revalve them with the koni inserts... dont know how much it cost, how long it will take, and what you will do to get around without your struts on your car. you could also just buy the tokico d-specs and just use the rears... almost the same price as just the rear konis.
also, the rear set of a coilover setup for a rwd sedan should fit since everything is the same(i cant guarantee it though). but if the ride height is where you want it to be, it will probably be cheaper to go with one of the options above.
Old Sep 8, 2006 | 11:25 AM
apintojr's Avatar
well the front is'nt really a problem. its just the rear. hmm gonna look into the shocks. but $$ isnt really an issue. i might go with coilovers for the rear so i can adjust the height at least. the rear sits a little lower then the front but its not bad at all.
Old Sep 8, 2006 | 04:37 PM
chobble19's Avatar
Thumbs up
i have h techs on my 6MT and i hadda a little rubbing but i got my fenders rolled and problem solved! you will always have rubbing with 8.5" + wide wheels i cant see 8" wide rears rubbing unless u are bottoming out!? ...plan on getting ur fenders rolled....
Old Sep 8, 2006 | 08:10 PM
apintojr's Avatar
rubbing is not the issue. its the bottoming out.
Old Sep 12, 2006 | 07:51 AM
apintojr's Avatar
ok, im going for it. now i will be going with either the HKS Hipermax LS coilovers or the Tein Type CS. wich would be the better ones. now i will be leaving in my Tein H techs in the front. just gonna install the rear coilovers.
Old Sep 14, 2006 | 09:51 AM
rayron's Avatar
wow, good luck. let us know how it goes. you should try and pm Gsedan35. he is an expert at this suspension stuff. he could lead you in the right direction. you might think about getting one with the controller in the car so you can adjust tension easily.... ex. you could stiffen it up if you're carrying a load. dont know if it will work with only the rears tho. try pm'ing Gsedan35
EasySausage
Sep 24, 2015 01:06 PM
Rhinos7777
Sep 6, 2015 05:36 PM
TheBay
Sep 3, 2015 03:27 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
