Sedan 6mt
Old Jan 19, 2003 | 06:25 PM
Lude2aG's Avatar
Sedan 6mt
Will the 6mt be around the same speed as the coupe?? and pro ands cons on it?
Old Jan 19, 2003 | 11:25 PM
Kegster's Avatar
Re: Sedan 6mt
Only Difference that I know of, is you don't get the rear vents with the 6MT Premium Package like you do with the Automatic, and the 6MT gets titanium trim and a different console around the shifter... also the 6MT comes standard with the sport suspension..
As far as speed goes, the 6MT should be faster then the Automatic..
Old Jan 19, 2003 | 11:27 PM
Kegster's Avatar
Re: Sedan 6mt
Didn't read your message right... sorry...
to answer your question.... No the 6MT sedan will not be faster then the Coupe... The Coupe has 20 more HP then the sedan... as far as 0-60 times goes, I don't see the sedan being much slower then a few tenths given the sedan is actually lighter then the coupe..
Old Jan 22, 2003 | 05:44 PM
Dan_1's Avatar
Re: Sedan 6mt
underated?!? I doubt it.. Nissan is pretty famous for overating there car engines output.. If you were to put it on a dyno, you probably see its only making around 220 hp @ wheels..
Old Jan 22, 2003 | 07:17 PM
Dan_1's Avatar
Re: Sedan 6mt
That dyno didnt have SAE Correction tho... so his numbers would be on the high side... If you read further down the posts you see another guy only got 213 hp @ wheels... so my estimate of 220 hp for the 6MT will be pretty close..
Old Jan 22, 2003 | 08:21 PM
G35Lakers's Avatar
Re: Sedan 6mt
Buzz killer! Just kidding. Dan, what's the difference between horses at the wheels and what's listed? In any event, the difference sure sucks. Is it like that for all cars?
Old Jan 22, 2003 | 10:04 PM
Kegster's Avatar
Re: Sedan 6mt
Here's a simple break down of the different figures...
Gross Horsepower: measurement of engine horsepower taken at the flywheel with no engine accessories attached, no restrictive exhaust system, and in a perfect state of tune (useless to the average consumer).
Net Horsepower: measurement of engine horsepower taken at the flywheel with engine accessories and exhaust system in place and in a normal or typical state of tune (also useless to the consumer).
Driven Wheel or Brake Horsepower: measurement of horsepower taken at the driven wheels on a dynamometer, reflecting how much power is available after an engine's accessories, exhaust system, emission control system and driveline losses have taken affect (very useful to know since it's a realistic measure of horsepower in the real world).
When you see peeps say 213 HP @ wheels, there talking about Driven Wheel Horsepower... the figures you see from a manufacturer are usally the NET HP figures.. Although sometimes they will try and pass the Gross HP off as the NET HP to make it look like there car makes more HP then it really does... Nissan tried that few years back on the Sentra and got caught by several car magazines.. hehe
Old Jan 22, 2003 | 11:20 PM
G35Lakers's Avatar
Re: Sedan 6mt
Kegster thanks a lot for the knowledge.
Tha G is da [censored]. <-G35Lakers
Old Jan 22, 2003 | 11:22 PM
G35Lakers's Avatar
Re: Sedan 6mt
censored means in a cleaner way -->#1 Stunna out on da roads.
Old Jan 23, 2003 | 12:44 PM
pestilence's Avatar
Re: Sedan 6mt
Cool. thanks for the info.. I diddnt konw that.
..pestilence..
tiguy99
Mar 1, 2016 11:42 AM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
TheKnite
Aug 14, 2015 07:59 PM
