2003.5 6mt - Lsd?
Old Sep 20, 2006 | 12:20 PM
Pska's Avatar
2003.5 6mt - Lsd?
As the topic states, Do the 03.5 6MTs come standard with a LSD? I did a search, but nothing came up!
thanks in advance.
Old Sep 20, 2006 | 02:54 PM
DaveB's Avatar
Nope.
Old Sep 20, 2006 | 03:09 PM
Pska's Avatar
was it an option? I mean, the car has the aero package and every option asside from navigation, would it be safe to assume that it
a) has an LSD
b) does not come with an LSD
and if b is the answer, are there LSD kits out there? Do I really need to look into it or will everything be ok?
thanks for the response dave!
Old Sep 20, 2006 | 03:31 PM
nghiars's Avatar
what do yo uguys mean by LSD?
Old Sep 20, 2006 | 03:33 PM
Pska's Avatar
sorry! its short for Limited Slip Differential.
Old Sep 20, 2006 | 03:36 PM
2006_G_coupe's Avatar
Limited Slip Differential.!!
Meaning both rear tires spin at the same time.
Leaving 2 burn marks instead of one.!!
I love my lsd...
Old Sep 20, 2006 | 03:42 PM
dklau33's Avatar
The LSD option first became available for the 6MT sedans in the 2004 MY. So no the 2003 6MT will not have it. You could swap in an OEM VLSD but the cost/benefit ratio just isn't worth it unless you get everything done for nearly free. There are plenty of aftermarket LSDs out there but it all depends on what you want. IMHO the Quaife would be your best bet since it drops right into your open differential. It's also the street friendliest since it is quite in operation, almost seemless in transition when locking up, and doesn't require schedulded rebuilds. If your goal is more for the track I've heard many good things about the ATS Carbon Diff since it has all the benefits of a clutch type diff but doesn't come with all the negatives either.
Old Sep 20, 2006 | 04:02 PM
Pska's Avatar
honestly, my goal is not the track, its jsut a Daily Driver, but I want to have fun! Im used to the MSP which DID have a LSD and have not driven a non LSD manual car before. Will I notice a huge difference?
Old Sep 20, 2006 | 04:48 PM
obender66's Avatar
You can still have fun-turn traction control off and let her rip.
Will do donuts and burn outs with no prob
Old Sep 20, 2006 | 06:23 PM
ttrank's Avatar
Grocery getter
I can't imagine having my car without the LSD. There is just too much power and no way to get it to the ground.
Blue Dream
Dec 5, 2015 10:56 AM
Learned Hand
Oct 1, 2015 09:02 AM
RWDguy4238
Sep 30, 2015 12:13 AM
