Another Wheel Question (uh oh!)
Old Sep 21, 2006 | 05:52 PM
Neal376's Avatar
Right now I am in Maine. I am getting wider wheels in the rear (from axis penta 8.5 (245/40/19) to 9.5) I have a 350z Revised drop
My 245/40's cleared the fender by a MM or two on a 35 offset....you think I can drive back down to NYC from Lewiston Maine on a 40 offset and 275/35's? (where I can then get my fenders rolled)? or should I get a smaller tire for my rear wheels.
these are my 245/40 on 35 offset(sorry for the bad pic)
Old Sep 21, 2006 | 06:04 PM
tkman00's Avatar
will a +40 work out back?
Old Sep 21, 2006 | 06:06 PM
seddon's Avatar
Neal you going staggered?
Old Sep 21, 2006 | 06:07 PM
Neal376's Avatar
i am asking you!@
yea, i am going staggard cause I got a dedicated winter set now for AWD on
Old Sep 21, 2006 | 06:12 PM
tkman00's Avatar
i think +40 is a bit extreme, it sounds like it will def require fender rolling. my setup was conservative and it was +55. +45 sounds about right
Old Sep 21, 2006 | 06:17 PM
Neal376's Avatar
+55?
neal is confuzled
my 35s where tucked in
Old Sep 21, 2006 | 06:23 PM
tkman00's Avatar
ur 35s were 8.5, my +55 was 9.5
reference only
Old Sep 21, 2006 | 06:26 PM
Neal376's Avatar
so ****ing confusing
Old Sep 21, 2006 | 06:49 PM
Chico's Avatar
First thing first...your tires are too fat if you want to go staggered on those wheels. Second, if I remember correctly...you have an AWD right? if so... I would not recommend going staggered. But if you still want to venture out here is what you need:
19x8.5 +35 with 245/35/19
19x9.5 +40 with 275/30/19 and slight fender roll. Your rear negative camber will help you clear it.
Idealy you want 19x9.5 +45 with 275/30/19
Old Sep 21, 2006 | 06:59 PM
Neal376's Avatar
oh ****!!! i just remembered!!
I have a SPC camber arm adjustable in the rear!!!
I can just dial out the neg camb until I roll my fenders!!!
Old Sep 21, 2006 | 07:33 PM
mrgags's Avatar
so Neal, r u driving with the AWD fuse pulled, or are u running staggered with the AWD on, i'm curious what would happen if u run staggered with the AWD on
Old Sep 21, 2006 | 07:49 PM
Neal376's Avatar
with AWD fuse pulled
anyone chime in?
I will run Nitto Neo-Gens with Neg Camb -
sound good to anyone? I think it will look HAWT
Old Sep 21, 2006 | 07:55 PM
KrazyEd's Avatar
Is it bad to run with the AWD fuse out all the time? I was thinking about doing this but I am not sure.
Also, do you lose power by doing this?
Old Sep 21, 2006 | 08:04 PM
ttrank's Avatar
Grocery getter
I thought the camber kits just pulled the bottom the wheel in to fix the camber. I don' think that will help the rubbing.
Neal376's Avatar
i think my vehicle is quicker with the AWD fuse pulled.
Ive been running w/o it for about a year now - no problems.
