Painted grill
Old Oct 5, 2006 | 09:03 PM
  #46
USERV35's Avatar
Originally Posted by driguez
i guess both ways it would be fine, the only dif is the primer, btw i used duplicolor and neal used rustoleum, if i had to do it again i would find a shelden williams and have them match the color to my car, but if you are doing black on any other color than OB it doesnt matter
Im going to redo mine and try priming it first and use lower grit paper! Ordere wheels today 2nd set first didnt fit but hopfully these will. I will post pics ASAP
Old Oct 5, 2006 | 09:09 PM
  #47
chobble19's Avatar
got my grill for sale http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Old Oct 6, 2006 | 06:50 PM
  #48
USERV35's Avatar
Originally Posted by chobble19
why will that not fit a 03-04?
Old Oct 6, 2006 | 11:02 PM
  #49
jack_burton's Avatar
In process, turning out well...
Okay guys i have some info as i'm in the middle of painting my grill right now. I used rustoleum as I have a friend in the industry that says rustoleum is one of the best for not chipping. here are the steps I used
1. Sand the mother down. I mean really sand it! It takes a long time but the better the sanding the more even it's going to turn out. I decided to just keep sanding instead of using paint remover.
2. I started with the rustoleum auto primer and used a whole bottle. It was probably about 3 coats total.
3. Then i sanded it down again, taking out all the nicks and extra paint that clumped up, evening it out entirely 400 grit
4. Then i used flat black rustoleum and used an entire bottle, another 3 coats.
5. Sand again 400 grit
6. Rustoleum glossy black finish
7. debating about clear coat?? i think i used enough coats but im debating about putting clear coat. I think it might make it too shinny, it's already there with the glossy black coat.
BTW i have a black sedan and went black with the grill
ill post pics tomorrow
Old Oct 6, 2006 | 11:05 PM
  #50
Neal376's Avatar
i used clear coat. didnt really make it any more shiny
but that sounds like the EXACT process I used, except I did not use any primer
Old Oct 6, 2006 | 11:34 PM
  #51
Neal
What type of clear coat did you use??
Old Oct 7, 2006 | 12:42 AM
  #52
DaveB's Avatar
Use clear to protect the paint and to give it some depth.
Old Oct 7, 2006 | 10:37 AM
  #53
madchef's Avatar
But he's worried about the level of gloss...he wants to keep it a flat black
jack, looking forward to the pics, and thanks for the steps that you used!
Old Oct 7, 2006 | 03:36 PM
  #54
fabolous G's Avatar
Thanx bro I have flat Black now ill try it with a clear coat next week ill put so pix up after
Old Oct 8, 2006 | 08:23 PM
  #55
alright guys i totally chunked the deuce
i scewed up sanding it so i decided to redo the entire project.
Here are some pics of how it should look all sanded. I used steel wool this type, the 2nd from the most corse to remove all the excess paint and stuff. It works a lot better than sand paper
<img src="http://myspace-999.vo.llnwd.net/01264/99/93/1264513999_l.jpg">
And then here is the first coat of primer.
<img src="http://myspace-138.vo.llnwd.net/01264/83/16/1264516138_l.jpg">
if u guys have any questions feel free to contact me as this is my second go around and i feel like a pro now at sanding lol
Old Oct 10, 2006 | 12:34 PM
  #56
USERV35's Avatar
I cant see the pics and I am almost done redoing mine. Im on the finishing touchs but it looks great this time. we will see how long it last though! Also Wheels are going on today too!!!
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
vQFamily
Sep 30, 2015 01:17 PM
