2005 sedan coupe midpipe installed
Old Sep 27, 2006 | 02:16 PM
gdo's Avatar
gdo
Just finished installing a coupe midpipe on my AT 2005 sedan. Installation was pretty easy. The only real issue I had was taking the sedan midpipe off the rubber hangers, even when soaked with WD40. The hanger ends "flares" out a little so it's a pretty snug fit when trying to pull them off the rubber hanger, otherwise the rest of the installation was simple.
Sound wise, it does add more of a deeper exhaust note than the stock sedan midpipe at startup. On the road, the volume is close, if not slight louder than the stock sedan midpipe but it has a slight deeper and a little more of a "raspy" tone to it. On the freeway and cruising at steady speeds, sound is exactly like the stock sedan midpipe. There might be a slightly lower exhaust note when you get to about the 75-80mph range. Barely noticeable change.
Regarding droning, There is very slight bit of droning at aprox in the 1700-2000 rpm range, most noticeable if the car is under load in the wrong gear. You have to pretty much "bogged" the engine before you hear this. I say 95% of the time, the tranny is smart enough to downshift. No drone if you are on a straightaway and the tranny is in the wrong (higher) gear.
Power wise, feels a little stronger off the line, maybe 1-2 hp down low. I really haven't open it up on top end but the butt dyno feels a little more throttle response on the freeway (ex: passing, merging, etc). I did this mod strictly for the sound so I didn't expect much power gains from it.
Overall, I think the mod is worth it if you really want a little more exhaust note from your car. If you are not into modifying cars, personally I would say
keep the stock sedan midpipe.
Let me know if anbody has any questions.
HTH
gdo
Old Sep 27, 2006 | 02:22 PM
FenixL1P's Avatar
the slight gain you speak of is from the slight weight loss in going to the coupe midpipe...
Old Sep 27, 2006 | 02:54 PM
gdo's Avatar
gdo
FenixL1P,
Yes, that's probably part of it too but the car does seem to rev up a little smoother. The coupe midpipe does have cleaner looking bends than the sedan midpipe, so probably a combination of a few things. Any power increase with the coupe midpipe is probably not worth mentioning.
gdo
Old Sep 27, 2006 | 03:01 PM
RocketG35's Avatar
Why do I bother to DIY???
Interested in selling your sedan middy? I have the coupe middy on my 03.5 and I don't like the droning...although 90% of the time the exhaust sounds great.
Old Sep 27, 2006 | 03:35 PM
gdo's Avatar
gdo
RocketG35,
Sorry, I think I'm going to hang on to it for now, just in case I decided to swap it back down the road.
Btw, how bad is your droning? When I did a search about a coupe midpipe on a sedan, I notice that when somebody mention droning with the coupe midpipe, they usually had a 2003 sedan. Wonder if something is different? Are you still running the stock muffler?
gdo
Old Sep 27, 2006 | 05:19 PM
SFG356MT's Avatar
I hope you're enjoying your new sound gdo.
Old Sep 27, 2006 | 05:58 PM
gdo's Avatar
gdo
Thanks! So far, enjoying the sound. Next mod, Motordyne 5/16" Spacer
Old Sep 29, 2006 | 05:55 PM
fabolous G's Avatar
put a clip on for the sound if you can I might want to swap mine too!
Old Sep 29, 2006 | 06:53 PM
G SEDAN's Avatar
for me, sometimes my exhaust sounds really quiet, sometimes it sounds like the Z. depending on the weather, my car sounds most like the Z when the air is very warm and dry. other times, it sounds a lil better but barely noticeable until past 4000 when my breather mods begin to scream..
laksjd84
Feb 28, 2026 01:58 PM
Blakelyg35
Aug 15, 2015 12:12 PM
lemmy999
Jul 25, 2015 12:13 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
