SEDAN: Sources and Links
Old Oct 24, 2003 | 12:39 PM
SoCalTed's Avatar
SEDAN: TechnoSquare - ECU
TECHNOSQUARE, Inc.
22521 S.Normandie Ave.,
Torrance, CA 90501
TEL (310) 787-0847
FAX (310) 787-0948
Email: contact@technosquareinc.com
FEATURES:
REV limiter modification
We found that with the ECU upgrade, more power can be gained with a higher rev limiter. A 7100 RPM (stock 6600 RPM) rev limit is set to take advantage of top end horsepower, while still providing a safe protection for the motor.
Speed Limiter Removal
The speed limiter is removed. The stock limiter was set at 234Km/h (146 MPH), so for all practical purposes, we could have left it alone. But we decided to remove it, just in case someone feels the need to go beyond that.
Ignition Timing Map Adjusted
There wasn’t much room for improvement at the bottom end since the ECU retards a lot of timing by using a feed back system in stock trim. So, we have added more timing at the mid range - higher end to take additional advantage of higher-octane gasoline. This aids in improving torque from 3000 rpm and up.
Fuel Map Adjusted
Stock fuel was set to detune the top end horsepower. We discovered that the car runs extremely rich after 5000 rpm. Air to Fuel ratio (A/F) of 10.5 was found right before the stock rev limiter kicks in. Cleary, Nissan was trying to detune the power output at higher rpm to discourage the driver from hitting the rev limiter. For the performance enthusiasts, however, this is unsatisfactory, so we set the A/F to 12.5 all the way to redline to provide adequate power gain while still maintaining a safe margin.
Drive By Wire Adjustment
Throught our testing we found, the drive by wire system was program to never fully open (throttle flap) when you smash the accelerator pedal. In fact, it actually closes the closer you get to the rev limiter, by as much as 20%. This restricts air into the motor and causes HP and Torque numbers to go down. We have remapped this setup so when you go wide open throttle, the throttle flap fully opens and STAYS open, increasing HP and Torque.
Adding to above modifications, a few other adjustments were made to other maps to enhance the feedback function which improves power, torque and drivability. The resulting achievement is a remarkable improvement in driving feel, which is more than what numbers alone can tell you. We are very satisfied with the results and are proud to release our TECHNOS ECU for this tuning-challenged ECU, blowing the lid off what was thought to be an automobile already running pretty near its maximum capability.
Changed air intake system
One of the major problems on this car was a feedback system that compensates for modifications. The oxygen sensors detects fuel mixture and will tell the ECU to richen up or lean out the mixture. This correction factor was way too wide, so some performance components upgrades (intake, exhaust) would actually result in a loss of HP below stock!
We adjusted the correction factor to reduce that compensation reaction. Our tests showed consistent power and torque improvement following installation of an intake system.
We will be conducting additional testing on various intake and exhaust systems for the compatibility of our ECU. Although we anticipate a dramatic improvement per component upgrades, some may require custom tuning to take full advantage of their performance.
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Quantum Tint 19% r, 28% fr, & 50% w/s
Clear Corners, 350z Duct http://www.cardomain.com/id/socalted
Old Oct 24, 2003 | 12:46 PM
SoCalTed's Avatar
SEDAN: Courtesy Nissan - Clear Corners
Courtesy Nissan of Texas
1777 North Central Expressway
Richardson, TX 75080
1.800.527.1909 or 1.972.644.3942
Mon-Fri 7:00am-6:30pm - Sat 7:00am-3:00pm
(Central Standard Time) Closed Sunday
You can also fax orders to:
1.800.382.7891 or international fax 1.972.234.4924
email: sales@courtesyparts.com
Sold in the Japanese Domestic Market (JDM) for the Infiniti 2003 G35 Sedan (4-door).
Sold as a set of two (2) clear corners lamps, one driver side and one passenger lamp. Amber light bulbs included.
Easy to install, installation instructions with diagrams include, however, installation text is entirely in Japanese.
Old Oct 24, 2003 | 12:56 PM
3point5SE_Auto's Avatar
SEDAN: Clutch Type LSD
Kaaz LSD
Phone at (949) 631-0990, fax at (949) 631-0909,
E-mail at: newportcars@kaazusa.com
Mailing address is:
Newport Exotic Cars
935-A Sunset Drive
Costa Mesa, California 92627 USA
LSD Exploded View
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Custom Catback
Old Oct 24, 2003 | 02:08 PM
nate's Avatar
SEDAN: Grubbs Infiniti - Drilled Aluminum Pedals
<a href="http://www.infinitiwholesaleparts.com/en_US/f_MiscPage_1.chtml" target="_blank">Grubbs Infiniti (aka Infiniti Wholesale Parts)</a>
1661 Airport Frwy
Euless, TX 76040
Phone 866-789-0207
Email <a href="http://www.infinitiwholesaleparts.com/en_US/ContactUsForm.jsp?pageName=ContactUsForm_1&pageTyp e=ContactUsForm&page_type_layout=ContactUsForm_con tactUs&siteId=a7d34b30117610048f2b0003ba192df4&ver sion=live" target="_blank">Contact Us</a>
Fax (817) 359-4104
<a href="http://www.smiley.net/g35/pedals.htm" target="_blank">Install guide</a>
<a href="http://forums.freshalloy.com/ubbthreads/postlist.php?Cat=&Board=UBB25" target="_blank">coupons</a> available at fresh alloy.
<a href="http://www.autovation.net/products/Infinity/G35/G35_pedals/main.html" target="_blank">Competitor/Option: AutoVation's Pedal's</a>
FYI - I did quite a bit of searching and this was the best price I found and was very happy with the ordering/shipping process and the parts themselves.
2003.5 Sedan Black/Black w/ sport, premium, aero, and winter packages.
Old Oct 29, 2003 | 10:10 AM
SoCalTed's Avatar
SEDAN: Crawford Z and Plenum
Crawford Z Car Service
Physical Address
We are Located Between Charlotte Ave. and Church St. at the Corner of 17th Ave. North and State St.
1622 State Street
Nashville, Tennessee 37203
615-327-4159 (M - F / 8am - 5pm)
CrawfordZCar@Comcast.net
Crawford Plenum
Price - $500.00
Original Plenum Core Charge - $200.00 (Refundable)
Lead-Time / Currently 5 - 10 Days, based upon available core returns and inventory with Nissan.
One of the largest contributors to performance loss, is the starvation of air within an engine. While the majority of people would never notice such a loss within their own engine, we began looking for causes of such a sharp decrease in power within the upper part of our powerband.
There is was, staring us in the eye. This very attractive molded plenum tucked underneith our plastic engine covers.
We still don't know why such an aggressive angle was incorporated into the design, perhaps to fit under the hood simplistically? Regardless, after flowbench testing we found there to be a 30% difference in flow between the rear cylinders and the forward.
In taking the current design, and raising the forward portion by nearly one inch... we reduced that difference to less than 5%. This was a HUGE discovery and one that has proven itself already on the dynos, and in the hands of MANY Z owners.
Can also be purchased from Strictly Z for the same price.
Old Oct 29, 2003 | 10:15 AM
SoCalTed's Avatar
SEDAN: Crawford - Headers
Physical Address
1622 State Street
Crawford Equal Length Headers
Price - $1300
High Temperature Powerdercoated - Silver
From preliminary prototypes to the finished production set in the car, Crawford's PROUDLY presents to you its EQUAL LENGTH HEADERS!
ANYONE can throw several pipes in, and make them equal length... though how smooth are those bends? Are they carefully designed? Do they just fit within the car WITHOUT rubbing? This is a HUGE issue for us, which is the explanation for our minute delays.
Crawford Headers are a DIRECT replacement of the OEM exhaust manifold. You DO NOT have to forfeit your cats if you wish to run these!
Updated dyno sheets will be posted as they become available after this cars dyno run on Tuesday, 28 Oct 2003. Notice the current numbers you see here are from the far more crude "throw-together" headers. We wanted to know if a substaintial enough power was going to be made, to make bringing these to the market realistic. In proving... the venture to put these final pieces with even SMOOTHER bends, thus MORE potential power... was sucessful!
What better way to compliment the other largest gain in NA bolt-on power current available on the market, The Crawford Plenum... than to pick up these and watch your power continue to soar!
Old Oct 29, 2003 | 10:20 AM
SoCalTed's Avatar
I don't know about the rest of you GS owners, but it seems we do a lot of searching to find sources for stuff. So, here is a link that I hope will assist us in our quests.
Please follow this structure for posting to make future searches easier. Make sure to CHANGE THE SUBJECT LINE so that it reads: SEDAN: "Vendor" - "Product"
for example: SEDAN: TechnoSquare - ECU
In the body of the Post add all the info you can, including:
*website,
*product pictures,
*product links,
*contact names
*phone numbers,
*email addresses,
*coupons/discounts,
*reviews,
*competitor links or pricing
and anything else you deem informative or appropriate.
N.B.--Please just resource material-- no casual posts.TNX
Cheers, Ted
Posts to this thread are not intended to be endorsements or advertising for the highlighted vendor. This thread is provided simply as a resource directory
Clear Corners, 350z Duct http://www.cardomain.com/id/socalted<P ID="edit"><FONT class="small"><EM>Edited by gsedanman on 10/30/03 12:13 PM.</EM></FONT></P>
SoCalTed's Avatar
SEDAN: Crawford - Plenum (polished)
Physical Address
1622 State Street
Polished Crawford Plenum
Price - $1,100.00
Are you the Z owner who is VERY into looks? Very into "blingage"? Then this is the plenum for you.
We had an OVERWHELMING responce on the initial plenum. Though there were still tons of people who wanted
the piece, but did not care for the more simple "race inspired" looks.
That's fine! We at Crawford began doing research seeing how fiesable it would be to construct a polished,
more importantly a SEAMLESS piece.
What you are looking at is the original plenum, with MANY more hours put into it! Dual welds both on the inside
and out. Extensive work on grinding down each of the outer welds. Then finally having it professionally
polished.
Old Oct 30, 2003 | 03:09 PM
SoCalTed's Avatar
SEDAN: NismoParts.com - Nismo Radiator Cap
Nismo Part.com JDM Radiator Cap
Best price so far.. .$29.38 + ~$8 s/h (U.S.)
Nissan OE radiator caps are rated at 0.9kg/cm (12.6lbs) for non-turbo vehicles and 1.2kg/cm (16.8lbs) for turbo vehicles. NISMO caps are rated at 1.3kg/cm (18.2lbs). Fits all Nissan manufactured from 1984 to present.
Old Nov 8, 2003 | 05:19 PM
SoCalTed's Avatar
Re: SEDAN: Nissan Wholesale Parts - 350z Duct
5031 North Galloway Ave.
Mesquite, Texas 75150
Tel: 800-876-7496
Fax: 972-279-9574
Email: parts@nissanwholesaleparts.com
Ask for Jayson, they run about $82.50 delivered
CLICK HERE FOR MODS - COMMENTS ALWAYS WELCOMED
Old Jan 12, 2004 | 01:52 AM
nate's Avatar
Re: SEDAN: Sources and Links
Why isn't this a sticky or in FAQ or something? This is a great resource that may get lost if something is not done.
2003.5 Sedan Black/Black w/ sport, premium, aero, and winter packages. See my profile for updated mods list and pics.
Old Jun 10, 2004 | 12:59 PM
SoCalTed's Avatar
bump...
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
Rose M
Oct 12, 2015 10:00 AM
Learned Hand
Oct 1, 2015 09:02 AM
doakley92
Sep 25, 2015 12:58 PM
