Idle speed
Old Oct 9, 2006 | 04:20 PM
RobD's Avatar
Idle speed
Hi,
I have new 2006 G35 6MT. Love it so far far. One question:
What is the normal idle speed? I only have 1000 miles on the
car. When I first got it it idled around 1000 rpms or so.
Now it idles around 2000. Did it go up because it's getting colder outside?
Thanks,
Rob
Old Oct 9, 2006 | 04:24 PM
soxx35's Avatar
it will idle higher untill the engine warms up alittle
Old Oct 9, 2006 | 04:25 PM
DieselX's Avatar
2k ? damn.. mine starts idling at about 1100 and then goes down to 600. Btw, i have auto.
Old Oct 9, 2006 | 04:27 PM
chinaman_87's Avatar
^ yeah mine is the same way
Old Oct 9, 2006 | 04:31 PM
ttrank's Avatar
Grocery getter
2000 is way too high if the car is warmed up. I had the dealer raise mine up to 850 when I put in the UR flywheel. It was between 600-700 before.
Old Oct 9, 2006 | 05:00 PM
chobble19's Avatar
Originally Posted by RobD
Hi,
Thanks,
Rob
do u have an AT or MT? 2000 is crazy high! after completely cooling then starting my idle jumps to 1500 or so and within a few minutes ends up sitting right around 850....i also had to have my idle bumped up a bit
Old Oct 9, 2006 | 05:06 PM
DieselX's Avatar
^^ lol, you quote him and it says 6mt.
Old Oct 9, 2006 | 05:16 PM
chobble19's Avatar
LOL dont ask how i didnt see that!
Old Oct 9, 2006 | 05:37 PM
ttrank's Avatar
Grocery getter
LOL. That was a good one.
Old Oct 9, 2006 | 07:35 PM
RobD's Avatar
It only idles at 2000 when the engine is cold.
It starts dropping down pretty pretty quickly...
2006_G_coupe's Avatar
Same here^
Old Oct 9, 2006 | 07:45 PM
Msedanman's Avatar
O.F. Administrator
Hi,
Thanks,
Rob
Your hot idle shouldn't be more than about 7-800 rpm. If it's higher, there is a problem. See the dealer.
Cold idle will vary depending on ambient temp, and isn't so important.
C.
Old Oct 9, 2006 | 08:14 PM
ttrank's Avatar
Grocery getter
If it's cold and then goes down quickly it might be ok. Do an ECU reset and see if it changes anything.
KruZZe
Feb 27, 2023 05:04 PM
aaron3719
Sep 29, 2015 10:12 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
vamarris
Sep 26, 2015 12:56 PM
Jnm07
Sep 5, 2015 01:16 AM
