TSBs done or not?
Old Oct 27, 2003 | 11:03 AM
Frag's Avatar
TSBs done or not?
I asked my dealer if any/all TSBs had been done to my car. I bought it as a demo with 5000 miles on it and its a 2003.5. He was looking at the computer screen at the dealership when I asked him and he said something like "Nothing shows as being needed" My question is does the dealership generally have a record of what has already been done and what needs to be done. Surely they do, but his answer just didn't lead me to believe that he really knew about my vehicle.
Obsidian, Willow, Premium, Aero, Sport
Old Oct 27, 2003 | 02:40 PM
ryoken's Avatar
Re: TSBs done or not?
Ask for a copy of the service record for the vehicle, instead of asking if anything needs to be done.
Many of the TSB's are only performed as-needed.. your car needs to exhibit symptoms before they fix it.
Old Oct 28, 2003 | 02:45 PM
Frag's Avatar
The headlight TSB...is that for early production 2003 models only?
Old Oct 28, 2003 | 03:10 PM
ryoken's Avatar
The only headlight TSB I'm aware of is the one where they install caps to keep you from adjusting the headlights yourself. It doesn't affect the operation of the car one way or the other, and isn't something I'd make a special trip to the dealership for. If it's this one, then it was only for early cars.. they started installing the caps at the factory.
Old Oct 28, 2003 | 03:32 PM
Frag's Avatar
okay, I thought of a better question than my original post. Are there any TSBs I should get done to my 2003.5 sedan if the dealer isn't showing any have been performed?
Thanks!
Old Oct 28, 2003 | 05:10 PM
nuttyprof's Avatar
oh yea! i need to know which ones apply to the 2003.5's as well. 6MT if thats important.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Oct 28, 2003 | 05:24 PM
ryoken's Avatar
If the dealer says your car is fine, and you don't have any specific issues with the car, then no.. it's fine. TSB's are mostly to-do's to address specific complaints, and not all cars have the problem.
Old Oct 29, 2003 | 07:14 AM
cato's Avatar
SouthernComfort Moderator
The circuit board was recalled and should be replaced. The brake
light switch should also be replaced. Make sure you get these done.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
DB/GroundingGear red 12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Old Nov 3, 2003 | 09:01 AM
Frag's Avatar
Thanks Cato
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
suprhulk
May 24, 2003 06:18 PM
DallyCurtis
May 8, 2003 12:48 PM
