sun roof automatic close not working
Old Oct 16, 2006 | 10:59 AM
G35DORME's Avatar
"It’s never enough”
Angry sun roof automatic close not working
Ok so yesterday my sun roof was working fine automatic open and automatic close was fine then all of a sudden my automatic close wont work I have to sit there and hold it all the way till its closed all the way the automatic open still works fine I don’t know what the f^ck happen. so here is what I did different when I got home I was closing the sun roof and I shut of the car (if you don’t open the door all the electrical keeps working) but I opened the door right before the SR was fully closed ever scents then the automatic close wont work what can this be if I disconnect the battery do you think it will reset and start working again?
Old Oct 16, 2006 | 11:07 AM
esfoad's Avatar
I copied the following from another post. I hope it works for you:
Reset Procedure for the Sunroof G35
1. Press the switch to the CLOSE/UP side to
tilt up the sunroof.
2. Press and hold the switch to the
CLOSE/UP side for approximately 3 seconds
while the sunroof is tilted up.
3. Release the switch once, then press and
hold the switch to the CLOSE/UP side
again for approximately 10 seconds until
the sunroof moves automatically.
4. The sunroof will automatically open and
then close all the way.
If you failed at procedure 3. repeat all the
procedures from No. 1.
Old Oct 16, 2006 | 11:17 AM
G35DORME's Avatar
"It’s never enough”
thanks alot ill try that later today
Old Oct 16, 2006 | 01:46 PM
damonb10's Avatar
Yeah, that procedure is in the manual. I had to do that once too. It resets the system. No problems since.
Old Oct 16, 2006 | 04:06 PM
4 Door Skyline's Avatar
Man I told you to stop stickin ur upper half of your body out and flashing people and then hitting the close button......LMAO
Old Oct 17, 2006 | 12:09 PM
G35DORME's Avatar
"It’s never enough”
OK it worked like a charm thank every one where would some of be w/out G35driver LOL
4doorskyline you know I can stop doing that its to fun
Old Oct 17, 2006 | 01:36 PM
hahahaha
Old Oct 17, 2006 | 02:25 PM
esfoad's Avatar
Now that you know the reset procedure, go ahead and have some FUN!
Old Oct 18, 2006 | 02:05 PM
CGYg35x's Avatar
I just want to add something to the instructions
"3. Release the switch once, then press and
the sunroof moves automatically."
In this step you must hold the CLOSE/UP button until the sunroof comes down, fully opens and then closes fully. If you only hold it until the sunroof starts to come down then the sunroof will only one touch open but not one touch close.
Old Oct 18, 2006 | 03:33 PM
G35DORME's Avatar
"It’s never enough”
Yea I did that the first time the second i held it till it was done and it worked fine. On another note im replying from my phone its prity sick LOL
Old Jul 15, 2007 | 03:08 AM
netcbc's Avatar
#4 doesn't happen for me I'm holding on to it but it doesn't open and close all the way???
Having problems with one touch tilt close, please help, thanks!
Old Jul 15, 2007 | 05:50 AM
clinthammer's Avatar
i had that problem first day i owned the car. apparently sensors were bad and they changed them for new ones. Never had issues since.
Old Jul 15, 2007 | 01:48 PM
netcbc's Avatar
nevermind followed this instructions and it fixed it
http://www.infinitihelp.com/Ownershi.../ITB03-060.htm
Old Apr 24, 2010 | 07:32 PM
matdaddy's Avatar
Good fix sticky this!!!! I was ready to take a crow bar to my car! Nice trick to play when it starts raining!!!!
Old Apr 24, 2010 | 10:36 PM
geew1z's Avatar
wait a sec... the damn sunroof is supposed to be able to close automatically from a tilt too???? m%$$%F#$$#(
tal1412
Nov 28, 2022 09:25 AM
nickmcc123
Jul 29, 2015 05:14 PM
julian.dion
Jul 29, 2015 09:16 AM
newg37
Jul 26, 2015 09:32 AM
newbdriver01
Jul 15, 2015 06:10 PM
