Was putting in a new battery Optima Red 35
Old Oct 23, 2006 | 04:54 PM
Jeff92se's Avatar
Red Card Crew
and noticed something odd. When you take the battery out, the bottom of the tray has two deep recesses with bolts. The both times I removed my battery, these holes had puddles of water. Now the tray is plastic and won't rust. But the bolts that are at the bottom (two of the 4 that hold the tray down) do. I removed the tray and looked under it. It's flat and there seems to be a drain hole near the fender. Since I didn't particularly want water sitting there forever, I drilled two drainage holes near the bolt holes (underside of the tray, near those bolt holes) there are two indented cast areas. I drilled two holes there so the water could train and have room to move out around the tray.
Anyone else notice this? You'd have to remove the battery for some reason to even tell there was water accumulation though.
Old Oct 23, 2006 | 05:02 PM
ttrank's Avatar
Grocery getter
I have had my battery out a few times and never had any water in there..?..
Old Oct 23, 2006 | 05:07 PM
Jeff92se's Avatar
Red Card Crew
It rains up in here in the NW and I've washed my engine down once. But I've cleaned up the tray once after I powerwashed the engine bay and there was water down there again.
So as a precaution I used a gob of anti-seize on those tray bolts. One for the rust issue and the other two for any battery corrosion that likes to get on the threads.
Old Oct 23, 2006 | 05:55 PM
MixturePinoy's Avatar
please post pics... rainy season is beginning again...
Old Oct 23, 2006 | 05:58 PM
Jeff92se's Avatar
Red Card Crew
No pics. And I ain't taking the battery out and losing all my presets again.
Old Oct 23, 2006 | 06:27 PM
willthethrill's Avatar
Are you sure its water and not battery Acid?? My stock battery was leaking and corroded all the bolts, I cant remove any of them.
Old Oct 23, 2006 | 06:37 PM
Jeff92se's Avatar
Red Card Crew
It tasted like water
It was water.
Old Oct 23, 2006 | 06:49 PM
ttrank's Avatar
Grocery getter
It was water.
LOL.
Yummy.
Old Oct 23, 2006 | 07:21 PM
khsonic03's Avatar
Yes, I noticed this as well. I didn't do anything about it though. Probably a good idea.
chinee
Jun 10, 2024 07:48 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
dimentio1
Aug 16, 2015 11:47 AM
chinee
Aug 8, 2015 10:11 AM
Jadenkid22
Jul 14, 2015 12:33 AM
