starting engine ... feel a sort of "kick" ??
Old Oct 27, 2006 | 03:02 PM
nadir's Avatar
when i start the engine up, I usually hear/feel a sort of "kick" or thud ... any ideas? Is that normal for the G? Sometimes it doesn't happen.
I'm thinking I just need to change the oil. I just bought my G so i'm not sure if it was always there or not.
thanks
Old Oct 27, 2006 | 04:14 PM
gianG35's Avatar
I have the same maybe worse problem than you.
It happens to me sometimes during cold starts. One time it was such a "violent" vibration that i shut off the engine, I then restarted the car but it wouldn't, so i checked the engine but didn't find anything out of the ordinary. My car was fine afterwards.
The strong vibration happened the day after i just changed the oil, but i don't beleive the two were related.
Old Oct 27, 2006 | 04:59 PM
ttrank's Avatar
Grocery getter
Hmmmm
How new is the car?
Might run some good fuel cleaner through it and see if that helps. I use the BG K44.
Old Oct 27, 2006 | 05:26 PM
Snewty's Avatar
i have the same 'problem' during a cold start in the morning. Feels like it is coming from the left side
Old Oct 27, 2006 | 05:30 PM
nadir's Avatar
yes exactly ... cold start and from the left side.
Old Oct 27, 2006 | 08:09 PM
AgentAero04's Avatar
Exact same thing here,just recent-it's on my list of things for the dealer to check.
04sedan/5AT/aero/prem/alpine nav
Old Oct 28, 2006 | 07:02 PM
jdm4eva's Avatar
Happen to me the other cold morning too and jumped the "Sh%t" out of me.
Old Oct 28, 2006 | 08:23 PM
Msedanman's Avatar
O.F. Administrator
It's happened on all my VQ's (occasionally) and it's the cam chain tensioner that gets dry of oil while sitting.
As long as the sound goes away after a few seconds, you'll be fine.
C.
Old Oct 28, 2006 | 11:47 PM
AuAltima3.5's Avatar
I experience a light thump in the driverside floor board on startup. It doesn't make any noises similar to a "bad" thing or a problem (no cracking or screeching).
Old Oct 29, 2006 | 01:51 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
C.
Yep, my wife's VQ did it every so often on first start of the day ONLY. First noticed this since the 10 mile mark(new) and same on my G.
dealer said no problems found.
Old Oct 29, 2006 | 01:57 AM
nadir's Avatar
so this is a VQ35 prob?
haven't experienced this on my VQ30
Old Oct 29, 2006 | 11:16 AM
DaveB's Avatar
It's the engine torqueing in the engine mounts. An engine starting and stopping creates a good bit of twisting torque. Sometimes this excessive torque will causing the mounts to pop or thud.
Blakearold
Aug 19, 2015 10:20 AM
maximino
Aug 12, 2015 02:05 AM
ClwMike
Jul 23, 2015 12:55 PM
