took my car to the dealership AGAIN!!!
Old Nov 4, 2006 | 06:48 PM
thintzen's Avatar
once again, i took my car into the dealership for front end noise....
the first time, they change the shock absorber cartridge, which was out of my extended warrany and i had to pay.
this time they changed my rack and pinion and links. stating that there was internal failure....pretty big job, and i'd think it would fix the clunking noise i get over bumpy roads.
WELL IT DIDN'T
to make a long story short, i'm getting tired of this dealership, and would want to take my car to another one.
how does this work with the extended warranty, can i just call any other dealership and make an appt, will my warranty be honored?
btw, any ideas what the noise can be from??
Old Nov 4, 2006 | 11:32 PM
ttrank's Avatar
Grocery getter
What kind of noise is it? The more details the better.
As for the warranty, any dealer should be able to work on it for you.
Old Nov 5, 2006 | 12:05 AM
thintzen's Avatar
its like a clunking noise. i only hear it over a sudden bump in the road, or a dip, like a pot hole or something....but the noise is loud....likie metal hitting metal.
at fast speeds on the highway, its not there , but whenever there's a suddden bump, or rough road, i hear it....
Old Nov 5, 2006 | 12:35 AM
ttrank's Avatar
Grocery getter
Have them look at your steering spindle. Mine was damaged and made sounds like that.
Also have them make sure everything is tight like your sway bars, etc.
Old Nov 5, 2006 | 07:32 AM
G SEDAN's Avatar
there was a rubber bushing for the rack and pinon (spelling) that was missing on my civic si and made that noise. I don't know if G's have it, but defintely check it out...
Old Nov 5, 2006 | 10:02 AM
Andy77's Avatar
I had an engine mount that was broken (on delivery in a new Saab 30 years ago) that made noises like that. Good luck.
Old Nov 5, 2006 | 10:44 AM
Noremac's Avatar
Lots of speculation here, but I wonder if this clunking noise could be ye old compression rod bushing problem. When it gets bad, it sounds awful too. It most often occurs on undulating surfaces such as driveway aprons, modest bumps in the road (especially dips and rises), gets worse in cold weather, etc. Sometimes it will be just a quick "crunch" sound, other times will actually vibate and rattle for a second. Just a thought...try doing a search here for "compression rod" and see if what people are describing might fit your problem.
Old Nov 5, 2006 | 11:34 AM
SFG356MT's Avatar
You mentioned an extended warranty. Did you purchase the car new and added the extended warranty? What year is your car and the mileage? If you did purchase the car new with an extended warranty (ie extending the factory warranty) you can take your G to any Infiniti dealership.
Old Nov 5, 2006 | 12:33 PM
thintzen's Avatar
03 g sedan...it was pruchased used form the dealer. the brochure infiniti sent me says its the "elite extended warranty" which covers me up to 100k miles. right now i have 63k.
Old Nov 5, 2006 | 02:00 PM
SFG356MT's Avatar
OK, so you bought it used but was it from an Infiniti dealer? If so was it a Certified Pre Owned vehicle? Certified vehicles can only be offered by dealerships selling the same brand used cars. Some of the reasons, at least in California, why a dealership won't certify a car is because of mileage, it has been modified or not in stock condition and or body damage that has been repaired. I worked for an Acura dealership and dealt with both new and used cars. If the car was certified it usually extends the factory warranty which is 4 years 60K (not sure what Infiniti offers). I would suggest taking it to another Infiniti dealership if possible and see if they can give you an idea what's wrong with the front end.
Old Nov 6, 2006 | 02:38 AM
G35r1d3h's Avatar
Might be your sway bar joints or like someone said ur engine mount. My old g35 had it too, one of the bolts for the engine mount wasn't tight enough.
good luck...
Hasanbaloch
Feb 29, 2024 08:45 PM
Frostbite91
Jul 27, 2015 05:25 AM
Karnicle
Jul 23, 2015 05:08 AM
brian_z
Jul 22, 2015 09:19 PM
Ninjay16
Jul 20, 2015 01:21 AM
