For those with staggered 20s...
Old Nov 16, 2006 | 07:24 AM
heyitzalex's Avatar
How much of a drop did you guys do? I currently have revised z springs and dspecs, the drop is definitely not enough. I'm currently thinking about going eibach sportlines 1.6" drop all around, and I most likely will have to roll my fenders. any input would be helpful. i've search like a mother and can't really find much on 20s and a drop. thanks.
Old Nov 16, 2006 | 08:38 AM
Floyds_racing's Avatar
I think right now I am about 2 all around!
Old Nov 16, 2006 | 10:16 AM
Good2Go's Avatar
I have 20's and Eibach sport springs - I think about 1.2" in front and 1.1' back. No rubbing at all.
Old Nov 16, 2006 | 10:49 AM
ttrank's Avatar
Grocery getter
I have H&R 1.3/1.2 and just tuck the top of the tire on the front and rear with 20x8.5/20x10 (245/35&273/30).
Old Nov 16, 2006 | 10:54 AM
vodkarocket's Avatar
Modded Member
With the offsets of your wheels, you won't need to roll the fenders.
As for drop, I was on Tein Basics, and they allowed me to set a perfect ride height- which IMO is when you can't get a finger in between the tire/fender on both front and rear. I would not suggest getting the Eibach Sportlines, or any other spring that drops your car over an inch without shocks to go with it. The ride will simply SUCK!
EDIT: You have D-specs. Whoops! Go ahead and get the Sportlines.
Old Nov 16, 2006 | 11:05 AM
Modded Member
And you have a coupe which makes it irrelevant.
Old Nov 16, 2006 | 11:23 AM
RocketG35's Avatar
Why do I bother to DIY???
Although I'm not running staggered 20s...I'm running 20's with a pretty good drop in my opinion. I have about a 1 finger gap in the back...and 1.5-2 in the front I think. And this is running 245/35/20 tires. Keep in mind that this is only a drop using Z/Coupe springs which is a conservative drop (1/2" rear - 1" front)...you can see it here.
https://g35driver.com/forums/showpos...6&postcount=28
Old Nov 16, 2006 | 11:44 AM
az1anbeethoven's Avatar
yeah, i feel yah...the 350z drop is not enough for me either...i'm probably going with tein basics soon...
Old Nov 16, 2006 | 02:24 PM
ttrank's Avatar
Grocery getter
Most of the time I see that drop it looks too mild for me but your's looks very nice. Great work!
Old Nov 16, 2006 | 03:12 PM
RocketG35's Avatar
Thanks Tim! I didn't do much except swap in the springs. It's weird, but even with the coupe 19s I previously had...it seemed like it dropped more than the 1/2", 1" drop everyone said I would get. The 20s also are slightly larger than OEM size...so it fills the wheel well better. I'm pretty happy w/ the stance.
Old Nov 16, 2006 | 05:09 PM
Good2Go's Avatar
sorry...didn't read the post carefully "sedan"...my bad
vitamin.v
Nov 7, 2019 06:10 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
Slammed_g35
Aug 28, 2015 07:08 AM
