Black Headlights?
Old Nov 19, 2006 | 07:31 PM
brandon123's Avatar
Black Headlights?
Hi,
I really like the look of the black housing in the these headlights, but I was concerned about the temperature of the HIDS affecting the lens. I asked the seller aboutit he told me that they were made for Halogen bulbs. My question is whats the big difference? Can it still work?
http://cgi.ebay.com/ebaymotors/03-04...spagenameZWDVW
Old Nov 19, 2006 | 07:32 PM
abcquackyxyz's Avatar
why dont you get your stock ones painted...dont buy any parts from ebay..they are all cheap quality stuff and fitment is bad..
Old Nov 19, 2006 | 08:00 PM
ILLicit's Avatar
fitment on those headlights is completely fine, but HID's dont fit in them.
Old Nov 19, 2006 | 08:18 PM
brandon123's Avatar
is there any kind of mod that I can do to make them fit?.....if not, how big of a deal is it to have the housing painted?....can u give me a brief explaination of how to remove the lens from the housing?...thanks
Old Nov 19, 2006 | 08:21 PM
ttrank's Avatar
Grocery getter
No you can't make them fit. The non-HID bulb is not the same. I believe it is an H1.
I painted my housings when I did my S2000 mod; why not just go that way?
Old Nov 19, 2006 | 08:36 PM
brandon123's Avatar
Can anyone recommend somewhere to take my headlights to get painted in the Tampa area? As well as a general mod. shop...Thanks for the input everyone btw...
Old Nov 19, 2006 | 08:53 PM
chinaman_87's Avatar
go here first :
https://g35driver.com/forums/faq-diy/81380-g35-sedan-headlight-removal-guide-3-simple-steps.html
then when you take your headlights unscrew the three screws that hold the lens and the headlight together then bake them in the oven @ about 200 - 250 for 5- 10 mins. then pry them open now the housing is attached to the lens. Unscrew the screws holding the housing and lens together. Now spraypaint the housing black and make sure you use paint that can withstand high temperatures. once done just reassemble everything and BAM you're done with the satisfaction of doing it yourself.
Old Nov 19, 2006 | 10:09 PM
brandon123's Avatar
ok that sounds great....just one more question....how should I reseal the lens to the headlight to prevent condinsation or moisture buildup?
Old Nov 19, 2006 | 10:17 PM
G35Dreamz's Avatar
I plan to black out my headlights and do a retrofit. I have the parts from my previous ride. From my experience with aftermarket blackhousing is that the clear coat on the outside of the lense flakes off. Not sure if these have clear coat on them or not. I would really be more concern with fitment.
Old Nov 19, 2006 | 10:50 PM
just put it back in the oven (so the sealant gets gooey again), take it out and clamp the lens back onto the headlight
Old Nov 19, 2006 | 11:12 PM
ttrank's Avatar
Grocery getter
That's all I did.
Old Nov 20, 2006 | 12:05 AM
brandon123's Avatar
sounds easy enough...thanks a lot
Old Nov 20, 2006 | 12:48 AM
G35Dreamz's Avatar
I would preheat the oven to 200°-250°, turn it OFF and leave it in there for 5 minutes. I heard from some that didn't turn it OFF and the housing melts.
Old Nov 20, 2006 | 01:09 AM
yeah ^^ what he said is very important! sorry i forgot to mention that.
bTanz
Oct 15, 2015 02:31 PM
Mick_L
Aug 25, 2015 04:27 PM
linedr89
Aug 17, 2015 05:11 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
