New transmission after 15 months!
Old Jan 13, 2007 | 12:30 PM
  #31
Hi-TechG35's Avatar
LMAO...so true had one and went through 2 trannys.
Originally Posted by DieselX
Acura TL ? lol
Old Jan 14, 2007 | 08:01 AM
  #32
04dkbluG35's Avatar
Don't think it is the K&N
Originally Posted by gtbigup01
Any of you guys with the whistleing sound have aftermarket airfilter/ CAI setup? The reason I ask is because when you step on the gas, some aftermarket filters ( K&N) does emmit a low whistling sound. Check on that before you start screaming XSMN. Just a thought.
I do have a Z Tube and K&N, but the reason I don't think the sound is coming from that is that it seems to be related to the speed of the car rather than the engine. It seems to get louder/higher as the car goes faster and then gets softer/lower as the car slows down. If it was the K&N, it seems like it would stop the second you got off the pedal. Also, it goes away after 5-10 minutes.
Old Jan 14, 2007 | 09:19 AM
  #33
gtbigup01's Avatar
Originally Posted by kpopseven
stop buying the cheap aftermarket cai ...
which year does the tranny have?
i just bought a 06 and been hearing all this stupid mess about the dam car tanny this tanny that
wtf i pay 43,000 for this dam car wtf
It has nothing to do with the cheap or expensive CAI. It has to do with the car sucking more air through the set up and the sound produced can the same as a whistle. I am not saying that is the problem. I am saying check to make sure it's not that first, then maybe it's the transmission indeed. BTW I have a 04 MT with 18,250 on it so I am a little concerned myself after reading this thread.
Old Jan 14, 2007 | 10:47 AM
  #34
Ken_G35's Avatar
I don't have anything aftermarket under the hood and I have the whistle. It's not the windows either. It happens for the first 10 minutes you drive it. It just started happening recently. I have an '05 6MT sedan with 21K miles.
Old Jan 14, 2007 | 02:35 PM
  #35
liukai's Avatar
same thing with me, no aftermarket intake. i do have a ztube and mrev, but that shouldn't matter at all.
Old Jan 14, 2007 | 10:07 PM
  #36
basus's Avatar
Originally Posted by AgisA
I just found out I need a new transmission. Was hearing a whistling noise when the car was cold; thought for a while my drive belts were bad.
This is 6MT 05 with 31 K miles, bought it 9/06.
Can I ask Infiniti to buy it back or give me Blue book credit to buy the 07?
I just started hearing a whistling kind of noise in the first few minutes when the engine was cold and after that it went away completely.
Could it be the same issue . Car has just 15500 miles.
Old Jan 18, 2007 | 01:14 AM
  #37
liukai's Avatar
i'm gonna leave my car overnite at the dealership next week, than drive there first thing in the morning to finally allow them to hear teh whistiling sound. i'll see hwo they respond to that. . .
Old Jan 24, 2007 | 03:07 PM
  #38
liukai's Avatar
MISSION accomplished. . .i left my at the dealership, went this morning for a test drive with the tech. taht whistling noise came up, so the tech contacted infiniti corp, and they told him to replace the tranny, so i'm satisfied at this point with their response. Now, next step is to convince them to install my aftermarket clutch/flywheel. . .
  #39
liukai's Avatar
Oh, my car as 16,000 milew on it, got it about 16 months ago
Old Jan 24, 2007 | 03:59 PM
  #40
kailep's Avatar
after reading this thread, now I'm worry about mine. I have an 04 with 18k on it. I do hear some whistle noise and I thought it could be from the k&n. I need an oil change anyway and I'll point that out to the tech.
Old Jan 24, 2007 | 05:14 PM
  #41
Greasy's Avatar
Great, I only put about 5K on my car a year. At this rate my warranty will be out just around the time the tranny dies.
Guess I need to driver her harder.
That is when she get's back from the body shop. I wrecked her 3 weeks ago. Poor thing only had 4800 miles on it.
2006 DG 6MT
Old Jan 24, 2007 | 07:53 PM
  #42
SFG356MT's Avatar
How loud is this whistle sound? I have a K&N with the Ztube and get a slight whistle sound (or sucking sound) but it seems more noticeable now.
Old Jan 24, 2007 | 08:42 PM
  #43
kailep's Avatar
It sounds like what you describe. I know our cars has an open duct for the stock filter box. I also removed the "power duct". I thought it would be the sucking sound that is common on opened filter, especially an oiled filter. For the filter sucking sound, you usually hear it when you let go the gas. I'll listen to it more carefully tonight to determine if it is filter related or not.
Old Jan 24, 2007 | 10:34 PM
  #44
Dudefish's Avatar
My 6MT has a very soft whine. I kinda like it. Hope my trans isn't about to crap out.
Old Jan 25, 2007 | 01:20 PM
  #45
liukai's Avatar
So like some have experienced, the dealership woudl instal my aftermarket clutch/flywheel, but installation woudl not be covered under warranty. So, i opted to stick with a new OEM clutch/flywheel. . pity.
As for teh tranny crapping out, i'm sure i coudl proabbly drive with my original tranny for many more thousand miles, but my tranny woudl deterioate quicker, and just get worse. So its a matter of catching it sooner, before its gets even worse later.
