Will 235-55 tires fit stock rim?
Old Dec 10, 2006 | 06:46 PM
khan29's Avatar
For some reason 235-50 are more expensive than 235-55 and 235-45, all 17 inch. Would it be ok to use 235-55 or 235-45 on stock 17 x 7 rim from 2003.5 6mt sedan? I am running 350z suspension so I'm lower by about 1". Also, anyone running ultrahigh performance all season tires? Any suggestions?
Old Dec 10, 2006 | 07:09 PM
G35Papa's Avatar
235/55 will put you above the 3% speedo rating you want to stay under. 235/50 would be a better choice. It will be almost at the exact same height as stock. They will fit a 7" wide rim but it will look buldged (over the side of the rim).
235/45 would worse than 235/55.
Even though you are lowered, I don't think you will have a problem clearing the suspension and the fenders with a 235. Should have more than enough clearance.
Old Dec 10, 2006 | 07:22 PM
5150DS's Avatar
Click on the link.
http://www.rims-n-tires.com/rt_specs.jsp
Also Discount Tire Direct will tell you alternative tire sizes if you enter your vehicle info.
Old Dec 10, 2006 | 07:53 PM
Garyv01's Avatar
go to tire rack.com and get Avon tech's around 110$ for tire(very resonable price IMO)...They are amazing and i have them in 235/50/17 on my stock rims. No complaints so far
Old Dec 11, 2006 | 07:55 AM
cato's Avatar
SouthernComfort Moderator
Michellen Pilot Sport A/S ....... excellent tire .... a bit pricy
Old Dec 11, 2006 | 03:55 PM
rijen1013's Avatar
im running 235-50 on stock 17's
Old Dec 11, 2006 | 05:45 PM
infini_'s Avatar
Dont cheap out.... and dont get 235-55... it will ruin the handling. If you cant get 235-50 on 17" wheels.... then you are better of sticking with the OEM size.... 215-55-17.... my favourite are Yokohama Avid VS4
Old Dec 11, 2006 | 07:25 PM
dyenboy's Avatar
Registered
i dun recommend 235 -50..i had it on mine..it jus felt wierd..couldn't corner as much as i did with stock tires..
Old Dec 11, 2006 | 07:53 PM
ttrank's Avatar
Grocery getter
I would at least go with a 225 if you can. Even the extra 10mm will help. Just make sure to keep the overall size as close to the stock as you can.
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
StephonW
Aug 5, 2015 12:05 PM
BlackGee35
Jul 31, 2015 11:04 AM
