Gas smell from exhaust?
on
Originally Posted by DaveB
Your G's cold start rev's were at 2000rpms? My 03 might see 1,500rpms for about 3 seconds on a really cold start, but after that it hangs out in the 900-1000rpm range until the engine warms a bit. I've heard of other G owners reporting extended high rpm warm ups. It must be a 6MT thing because a 2000rpm extended cold start with a 5AT would mean the car would tkae off hard without the brake.
As for the Altima, yeah, they're stinkers. We had a 94 and 97. With as bad as our Subaru stinks, I thought for sure the O2 sensors were crapped out, but my datalogger says all is good. It tested fine for Georgia emissions too about 6 months back. It still gets 23mpg in the city and 29mpg on the highway.
Do you smell "unburnt raw fuel" or that smell you get when someone removes the cat (real stink). If it's gas, your cat is dead. If your car had a miss fire and sent raw gas to the cat, it will destroy it in short order (should have been a code thrown). If it just stinks, you may even have a cat or someone knocked the catalyst out of the unit and is running no cat. (is it loud?).
One last thing, does it stink while running after you have been driving for, say, a half hour or so, that gives the cat time to get up to proper temp (should take about 5 to 8 minutes)?
All cars do this on a cold start because the air/fuel ratio is very rich prior to the engine warming up. Some cars are worse than others. My wife's 98 Legacy GT is horrible on a cold start. I open the garage and back out immediately to keep the fumes from building in the garage.
man my cars smells like unburnt fuel,u can smell it inside out if i stand next to the exhaust out i can smell it and i can smell it inside the car and ya i have gutted cats,took em 6 months ago and he gutted them without removing them...so basically they r like test pipes but narrower on a certain point inside the cat cuz the designof stocks cats is equal all through the the cat....when i punch the pedal the smell gets more especially on highways when im on low revs inside the city i dont smell it a lot but its still there...am afraid that theirs a leak somewhere...or it may be too rich a/f thnx guys appreciate it
#30
Highest I've seen it go is 1800 or a little under.
And yeah this is in Winnipeg winters.
Thebaws11
07-02-2021 11:36 AM
Mad A
Not G35 Related
12-08-2015 01:45 PM
Rhinos7777
09-06-2015 05:36 PM
