Gas smell from exhaust?
Old Dec 10, 2006 | 10:28 PM
mfvep1's Avatar
Just got a used 2004 auto, very happy with it until today, when I was reversing into the garage .. smelled a strong gas smell coming from the exhaust. But didn't see any visible smoke. Also the smell is only there when the engine is running, and there are no puddles under the car. Any thoughts on what it could be? Fuel injectors? I have no clue
Old Dec 10, 2006 | 10:37 PM
Nismo G's Avatar
All the Gs do that wait until you throw test pipes on there and you have no resenator...then you are going to smell some fumes!!!
Its normal though dont worry about it!
Old Dec 10, 2006 | 10:55 PM
kraqcommando's Avatar
lol our gas milage is so bad you can smell the gas from our exhuast
Old Dec 11, 2006 | 12:16 AM
Nismo G's Avatar
I came from a 2500HD chevy so my gas mileage on the G is like having a motorcycle!!!! haha
Old Dec 11, 2006 | 08:02 PM
ttrank's Avatar
Grocery getter
I think you are ok. I can smell mine most of the time.
Old Dec 11, 2006 | 08:43 PM
DaveB's Avatar
All cars do this on a cold start because the air/fuel ratio is very rich prior to the engine warming up. Some cars are worse than others. My wife's 98 Legacy GT is horrible on a cold start. I open the garage and back out immediately to keep the fumes from building in the garage.
Old Dec 11, 2006 | 10:49 PM
mfvep1's Avatar
Thanks for the input. I talked with the service advisor today, and she was saying that it was probably because of a bad throttle body or carbon buildup in the engine, which happen to require about a $200-300 service. I guess that's possible, but it's good to know that other people here smell the same thing and it might be normal after all. Anyone else?
Old Dec 12, 2006 | 01:07 AM
DaveB's Avatar
That is a huge load of BS. It is not possible. Why in the world would carbon build up cause fuel odor? These service advisors amaze me.
Old Dec 12, 2006 | 06:25 AM
jimmykce1's Avatar
LOL..The key word is advisor, so they are not mechanics
Old Dec 12, 2006 | 11:53 AM
G35_TX's Avatar
Not all. Most Nissans do it really bad. Our Camry did it as well.
But my Acura does not and neither did my Audi.
Old Dec 12, 2006 | 12:58 PM
Bigd2k6's Avatar
I'm surprised she didn't say they're you're muffler bearings going out and allowing fuel to leak out your exhaust.
Old Dec 12, 2006 | 04:42 PM
DaveB's Avatar
Come live in a region and where the temps drop into the sub 20s at night. I'm certain your TL would stick up the joint on a cold start in a 30 degree garage My friend's 05 TL is probably worse than my G on a cold start. In the warmer months, the odor isn't remotely as bad.
Old Dec 12, 2006 | 04:44 PM
MixturePinoy's Avatar
It'll get stronger... learn to love it
Old Dec 12, 2006 | 05:46 PM
G35_TX's Avatar
It was 25 degrees over the past few weeks a few times down here and it did not start up like any Nissan does. It's rev's were around 1200 rpm not 2000 like the G35 or other Nissans are. And it doesn't create that odor.
Then try to start our 01 Altima, phew.
Old Dec 12, 2006 | 06:53 PM
DaveB's Avatar
Your G's cold start rev's were at 2000rpms? My 03 might see 1,500rpms for about 3 seconds on a really cold start, but after that it hangs out in the 900-1000rpm range until the engine warms a bit. I've heard of other G owners reporting extended high rpm warm ups. It must be a 6MT thing because a 2000rpm extended cold start with a 5AT would mean the car would tkae off hard without the brake.
As for the Altima, yeah, they're stinkers. We had a 94 and 97. With as bad as our Subaru stinks, I thought for sure the O2 sensors were crapped out, but my datalogger says all is good. It tested fine for Georgia emissions too about 6 months back. It still gets 23mpg in the city and 29mpg on the highway.
