She has twins, greddy twins that is...
Old Mar 16, 2008 | 09:56 PM
  #886
ttrank's Avatar
Grocery getter
Originally Posted by MardiGrasMax
Sweet, I just passed the 1k mile mark on my set up and am so anxious to start the serious tuning. When/if you take it to the drag strip what tire set up do you plan to run?
I've taken it to the drags a few times with the stock block setup and the oem 3.5 rear end. Results were not good, traction was no where to be found. Now I have a 3.3 rear end and am going to try some 275 BFG drag radials.
Old Mar 18, 2008 | 11:41 PM
  #887
psedog's Avatar
Back in SD**
Originally Posted by OCG35
Like Christmas in March!
You must be sooo anxious! I know I would be!!!
Try Christmas in Jan, Feb, Mar, Apr, etc It never stops for this guy
Old Mar 27, 2008 | 10:23 PM
  #888
Alex '09's Avatar
So which turbo kit would you recomend, and about how much will it cost to get it installed and running?
Old Mar 29, 2008 | 02:23 AM
  #889
ttrank's Avatar
Grocery getter
Greddy.
A good basic setup would run ~$10k.
Old Mar 29, 2008 | 02:24 AM
  #890
ttrank's Avatar
Grocery getter
Here are a few pics from last Monday.
Old Mar 29, 2008 | 06:30 PM
  #891
Alex '09's Avatar
Alright, thanks, that's what i thought, just had to make sure.
Old Mar 29, 2008 | 07:33 PM
  #892
MardiGrasMax's Avatar
Lookin good! Got it on the dyno yet?
Old Mar 29, 2008 | 10:27 PM
  #893
ttrank's Avatar
Grocery getter
That was taking the motor out. It won't got back in for ~10 days. Then we will get a good baseline tune on the car, drive it for a couple weeks and then go for a big number run.
Old Mar 31, 2008 | 05:48 AM
  #894
machavez702's Avatar
Tim, you and your car are a legend. Can't wait to see what you can extract from it.
Old Mar 31, 2008 | 10:57 AM
  #895
ttrank's Avatar
Grocery getter
LOL, thanks
The sedan fuel pump outlet and hard pipe are not the same as the coupe so I could not upgrade my return kit to a stage 2, that will limit my output. After the base tune is on the car for a couple weeks we'll see what it can make. I would like to see ~500-525 on crappy AZ 91 and high 500's on C-16.
If I don't make over 500 we are going to try to adapt the AAM stage 3 fuel system to my sedan. Or make something like it...
http://www.alteredatmosphere.com/mm5...y_Code=350Z_FS
Old Mar 31, 2008 | 10:38 PM
  #896
If you dont get over 500whp with the walbro in a sedan fuel system on C16 its tme to find a new tuner
Old Apr 1, 2008 | 01:42 AM
  #897
ttrank's Avatar
Grocery getter
I'm sure I'll get well over 500 on C16. The goal was low to mid 500's on pump.
Old Apr 1, 2008 | 01:48 AM
  #898
codeflux's Avatar
jesus christ man... it never ends, does it?... looking forward to your results - living vicariously.
Old Apr 1, 2008 | 02:12 AM
  #899
ttrank's Avatar
Grocery getter
Not that I can tell.
Old Apr 1, 2008 | 02:17 AM
  #900
B L U E S L A T E's Avatar
Honda Accord
You're crazy, TIM!!
In a good way of course!
