She has twins, greddy twins that is...
Old Apr 5, 2008 | 11:35 PM
  #946
AGThing1227's Avatar
Originally Posted by ttrank
Yeah I have tried to avoid looking at the front of my car for the last 6 months. I like the impul one a lot but it needs more IC room to work for me, 2/3 of my IC does not get direct airflow right now. It's much more of a N/A or small IC bumper.
I'm always lookin for some lovin!
I always wondered why your bumper looked fugly. I didn't want to say anything, because i'm a nice guy like that Ha.
Old Apr 6, 2008 | 12:22 AM
  #947
psedog's Avatar
Back in SD**
Just found out that UMS did not finish the motor so it won't be done until Monday or Tuesday.
Looks like all my plans are going to be pushed a few days.
With any luck I won't have to travel for work until the next week and will have my car back by the end of next week.
All big projects get pushed back, right. I mean look at yours. It has been going for 2.5 years
Old Apr 6, 2008 | 10:36 AM
  #948
ttrank's Avatar
Grocery getter
Yeah the clear coat went foggy when I put it on and it's been a mess ever since.
Old Apr 9, 2008 | 04:07 PM
  #949
tig488's Avatar
good luck with it! it looks great.
Old Apr 9, 2008 | 06:11 PM
  #950
ttrank's Avatar
Grocery getter
Thanks!
We're still waiting for some valve shims which should be here tomorrow. If so we will start putting it back in Friday and with any luck be done Mon or Tues.
Got the valve and timing covers back from the painter, they look hot! Don't have any pics yet because they are up in Prescott with the car and I'm down in Phoenix (80 miles away). Also got my new front end today which I can't wait to get painted and put on.
The manifolds, turbo exhaust housings and downpipes should be back from the guy doing the high temp coating today.
Old Apr 10, 2008 | 04:46 AM
  #951
Andrei's Avatar
LOL, thanks
The sedan fuel pump outlet and hard pipe are not the same as the coupe so I could not upgrade my return kit to a stage 2, that will limit my output. After the base tune is on the car for a couple weeks we'll see what it can make. I would like to see ~500-525 on crappy AZ 91 and high 500's on C-16.
If I don't make over 500 we are going to try to adapt the AAM stage 3 fuel system to my sedan. Or make something like it...
http://www.alteredatmosphere.com/mm5...y_Code=350Z_FS
This is a stupid question but cant the fuel pump outlet and hard pipe be changed? Or anything else that can be done? This is not something I thought would be a problem.
Old Apr 10, 2008 | 11:04 AM
  #952
ttrank's Avatar
Grocery getter
No, it's plastic so you can't make it larger.
Option #1 would be to replace/modify the tank to use a coupe/Z pump assembly.
Option #2 would be to replace/modify it with a CJ stage 3 dual-pump setup.
Option #3 would be to modify the AAM under car race pump/surge tank setup to fit the sedan.
Option #4 go full custom
Just thought of Option #5, use a voltage boost to raise the voltage of the pump for more pressure. I don't want to do this because it's more of a band-aid IMO.
I'll know in a few weeks if I need to pick one of these or not. I have a single W/255 right now with a CJ stage 1 return kit and RC 750cc injectors. Let's see how far that gets me.
Old Apr 10, 2008 | 01:23 PM
  #953
68_GT's Avatar
plus it greatly reduces the life of the pump
It may depend on the amount of voltage added, but Mustang guys have been doing this to the OEM fuel pumps from OEM supercharged vehicles and I've heard of them being replaced every three months.
Old Apr 10, 2008 | 02:13 PM
  #954
Andrei's Avatar
I like that option. Can it be easily done? What is the cost?
Old Apr 10, 2008 | 02:42 PM
  #955
ttrank's Avatar
Grocery getter
No, from what I understand it's not easy but can be done. You have to cut out baffles in your fuel tank and do some modifications to get the float to work right. I would expect it to be quite expensive unless you DIY.
Old Apr 10, 2008 | 10:25 PM
  #956
ttrank's Avatar
Grocery getter
Got my parts back from the guy doing the coating last night.
2000 degree coating should help keep under-hood temps down a bit.
Old Apr 10, 2008 | 10:51 PM
  #957
codeflux's Avatar
damn! pure sex. never seen black hightemp coating - looks awesome.
Old Apr 10, 2008 | 11:45 PM
  #958
machavez702's Avatar
sweeeet!
Old Apr 10, 2008 | 11:56 PM
  #959
ttrank's Avatar
Grocery getter
Well if UMS ever finishes my motor I can find out how well this does. They have had my motor since the 26th and told me 1-2 weeks at most to build it.
Old Apr 10, 2008 | 11:58 PM
  #960
Wannabe6MT's Avatar
-MN G Crew-
Damn TTrank. You never cease to amaze me.
