compression rod replacement
Old Dec 21, 2006 | 04:02 PM
governor's Avatar
Having my front compression rod replaced at dealer as we speak. My question is do I need to have a wheel alignment performed due to this?
FYI- This was the thrid time taking it to infinit for the suspesnion creaking noise. first lube, then soem BS part replaced and finally compression rod. I know the sounds will evnetually come back, but atleast now I have a record of the problem and fix.
Old Dec 21, 2006 | 05:57 PM
Noremac's Avatar
Congrats for finally getting your dealer to solve the source of the problem! Good news - you do NOT need to align the car after replacing the compression rods.
Old Dec 21, 2006 | 07:06 PM
lexusk8's Avatar
I got my front end compression rods replaced a while ago at the dealer, and I didn't need to get a wheel alignment done.
Old Dec 22, 2006 | 01:41 AM
governor's Avatar
so whats going to happen when the noise comes back and my warranty is expired? Will Infiniti do anything?
Old Dec 22, 2006 | 08:28 AM
SixFive's Avatar
Doubt it - unless it's a TSB - and even if it is many dealers don't know or care that it's a TSB and will try to suck the money from you pockets like crack hungry ******.
Old Dec 22, 2006 | 08:46 AM
lexusk8's Avatar
Well, on the back of the Infiniti receipt, it says that limited warranty for replacement parts and accessories is good for 12 months or 12,000 miles, whichever comes first, from the date of purchase. I assume that if the compression rods start to get noisy before 12 months or 12K miles, you have a fair case of bringing the car to the dealer to get them replaced under that limited warranty policy.
MyfistYourFace
Aug 8, 2015 11:58 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Jul 15, 2015 08:31 AM
