If I Go With 19s
Old Dec 22, 2006 | 12:20 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
19x8.5 +38 all around will work perfectly and be pretty flush with the fenders. You have an X and dont plan on lowering so there's pretty much no wheel you can get and have it rub.
If you put 19's you wont be higher off the ground. As long as your tires are near that of the stock tires diameter. The most common tire setup is 245/35/19 but if you want more rubber for peice of mind then 245/40/19 will work.
-GP-
Old Dec 22, 2006 | 12:41 PM
VQ Hotness's Avatar
Well with me my car is at the Exact hight it was b4 with the stock rims do to the lower Profile tire i went with.
Old Dec 22, 2006 | 01:43 PM
KrazyEd's Avatar
19x8.5 +38 to plus +40 offsets are the most common sizes for those who stay non-staggered. Since you have an X, you are not gonna want to run staggered unless you plan on pulling the fuse.
smellyg35
Jul 8, 2005 06:27 PM
PeteNJ
May 28, 2005 02:20 AM
tkman00
Feb 13, 2005 10:42 PM
4mrBMWguy
Jul 11, 2004 08:28 PM
