Got Alluminum Pedel Kit For X-mas
Old Dec 27, 2006 | 10:51 AM
Andyl's Avatar
Just Curious I Have An 04 X Sedan And Was Wondering How Long It Takes To Put In The Pedal Kit?
Old Dec 27, 2006 | 11:25 AM
abcdang's Avatar
10 min
Old Dec 27, 2006 | 12:38 PM
G SEDAN's Avatar
and 9 of those minutes you will be figuring out how top take the pedal off LOL
Old Dec 27, 2006 | 12:56 PM
jameyb's Avatar
Helpful tip I learned from another member:
Boil some water, take the water off the burner, put new brake pedal in hot water, install other pedals, remove brake pedal from water (be careful it will be hot), install new break pedal, done.
That is the only way I could get the brake pedal installed.
Old Dec 27, 2006 | 12:58 PM
madchef's Avatar
+1 on the hot water....but it's not the easiest thing I have done.
Not complicated at all, but it takes a bit of 'effort'
Old Dec 27, 2006 | 01:35 PM
cmthresher's Avatar
def.. takes some elbow grease. I used a blow dryer and heated mine up. and it was still a pain in the a** to get them on.. Good luck. but its well worth it. After having an 05' and going to an 03' later. I had to upgrade the pedals.
Old Dec 28, 2006 | 07:41 PM
G SEDAN's Avatar
i left mine on the roof of my mom's car while installing other pedals...this was in may in california so that wouldnt work right now....the point we are making is......you have to "slip" the brake pedal over....and trust me...its a lot harder than you'd think with those hard *** rubber and aluminum pieces..good luck!
Old Dec 28, 2006 | 08:30 PM
Cobra-2-G's Avatar
Those pedal kits suck!! You should just sell it to me instead so you are not burdened with the task of installation. hehe
I have seen the water thing work to loosen the rubber up, but also using some dish soap to slip it over the pedal easier.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Tonka211
Sep 18, 2015 09:46 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
