Which would be a better suspension set-up?
Which would be a better set-up for my 03 sedan? 350z revised with springs and shocks all the way around or g35 coupe sport suspension all the way around. Oh I don't have the sport suspension currently.
I just picked mine struts and springs from a 06 Z (I don't have sport suspesion either) along with a set of Hotchkis sways to round off the package. I should have it all installed within the next 2-weeks.
I also have an '03 but mine does have the sport shocks. Should I go unrevised with my shocks or revised with 350z shocks to match? Is there much difference? I do have 54K on my car, so the shocks already have some wear. Also, are all 350z stock suspensions the same, other than the revised/unrevised versions, or are certain models different?
350Z.
If you want better performance and adjustability, go with some Tokico D-spec struts with the 350Z springs.
Since you have the sport struts now, you can get away with using the un-revised springs. It would be better to replace them while you are in there but if cash is tight you are ok.
Cool. Keep us informed about the set-up.
I picked up everything this weekend. The Z-suspension is coil-overs in te rear and strut/spring in the front. Sways were delivered late on friday and the things are monsterously big - can't wait to get everything on and I will post pics of the process.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
