245/40/18 of diameter for tire size?
Old Jan 19, 2007 | 12:22 AM
dnr777's Avatar
I posted a question about the best tire size for my new wheel, 18-8 volk progressive ME and I have got some responses from you guys. However, It did not make sense to me, so I could not buy tires today.
I want get front tire 225/45/18 and rear tire 245/40/18.
Is there anyone who knows 245/40/18 of diameter for tire size?
Also, 225/45.18 for front and 245/40/18 for rear will be a good balance? - I don't want to get my new wheels rubbing fenders.
225/45/18 25.9
235/45/18 26.3
245/45/18 26.6
245/40/18 ?
Old Jan 19, 2007 | 01:25 AM
Tunerz_Store's Avatar
must know offset of wheels to answer that question.
Old Jan 19, 2007 | 01:31 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
if you have 18x8's all the way around, you can just do 245-40-18's on all four corners, then you can rotate the tires as well to prolong the life.
overall diameter of 245/40/18 is 25.7"
-GP-
Old Jan 19, 2007 | 01:43 AM
jameyb's Avatar
This should help, you can plug in different sizes and see how they compare:
http://www.1010tires.com/TireSizeCalculator.asp
Old Jan 19, 2007 | 02:57 AM
G35Papa's Avatar
As long as you don't have an X you can run 225/45 front and 245/40 rear without any issues. Both sizes are close enough to OEM specs that you shouldnt have an issues.
Old Jan 19, 2007 | 03:14 AM
SFG356MT's Avatar
I'm running the exact same size and I'm lowered about 2inches without any problems. +38 offset
Old Jan 19, 2007 | 08:13 AM
Avinator's Avatar
Hey Guys,
First off, I don't mean to hijack the thread but I figured it would be better than starting a new one.
In regards to offsets, is the higher offset, say +40, going to move the rim closer to the inside of the fender or closer to the outside of the fender?
I am thinking about getting an 18x8 rim with a +40 offset front and rear with a 245/45-18 tire. I am running the unrevised 350z springs too. I have read the charts and looked at the diagrams and it looks ok to me but I would like to hear that from you experienced guys.
Thanks.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
