Does a 20 x 8.5 rim stick out to far in front?
Old Jan 24, 2007 | 02:15 PM
EAndrews's Avatar
I'm looking at some TSW rims off a Mustang and was wondering if not staggering the front looks bad or not? Anyone done this size up front on the Sedan?
Old Jan 24, 2007 | 02:17 PM
Hi-TechG35's Avatar
The fronts on the sedans are usally 8 to 8.5. I only know this because a couple of friends have sedans with 8.5's in the front
Old Jan 24, 2007 | 02:18 PM
EAndrews's Avatar
Perfect, I think they are all 4 8.5"w rims... so I should be good and lot thicker profile than the OEM sticks
ttrank's Avatar
Grocery getter
Not if they are the right offset. Check out the link in my sig "my car".
Those are +40.
Old Jan 24, 2007 | 02:23 PM
EAndrews's Avatar
First off, I love your ride man. One of the cleanest Sedan's i've ever laid eyes on.
Second, what offset can I get away with. here's the rims I'm looking at here locally.
http://cgi.ebay.com/ebaymotors/ws/eB...4074&rd=1&rd=1
Old Jan 24, 2007 | 02:26 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
as long as the offset is +35-45 they wont stick out of the fender. Anything lower and they will.
I'm running +38 on my 8.5" wide fronts and they're perfect.
-GP-
Old Jan 24, 2007 | 02:28 PM
EAndrews's Avatar
-GP-
right on... preciate the feedback fellas. I think these are both 35 or 40 in front and back.
Old Jan 24, 2007 | 02:29 PM
az1anbeethoven's Avatar
the new body style mustang takes a high offset...much like our sedans...so i believe those rims will work...double check with the seller on those offsets...the part i'm afraid of are the tires, which are 255/35...its going to be 50/50 if you are going to rub or not...but if you plan on lowering your car, good luck with that size of tires
Old Jan 24, 2007 | 02:50 PM
he shouldnt have a rubbing problem with the 255's, they're only about 10mm wider than the 245's. If the offset is +40 on all the rims then he wont have a problem with rubbing even if it is lowered.
-GP-
Old Jan 24, 2007 | 02:55 PM
EAndrews's Avatar
Not going any lower right now so I have time on that. I like my soft caddy feel right now
Old Jan 24, 2007 | 04:57 PM
ttrank's Avatar
Grocery getter
I tried 255's on my Zenetti wheels which were ~+38 and they rubbed. Otherwise I would have 255's right now.
Old Jan 24, 2007 | 04:58 PM
ttrank's Avatar
Grocery getter
Thank you.
Old Jan 24, 2007 | 05:21 PM
EAndrews's Avatar
ut oh. yea but you're sitting down 3 inches...
so am I gonna have issues then with the stock suspension you think?
Old Jan 24, 2007 | 05:34 PM
ttrank's Avatar
Grocery getter
LOL, I'm only lowered 1.3F / 1.2R.
You will not have the same problems as I do if you are stock height. 255's should be fine.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
DimQ
Aug 14, 2015 02:04 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
