Starter/starter solenoid question
Old Jan 28, 2007 | 06:21 PM
GM1964's Avatar
Hey Guys,
Good forum. Just a quick question.
Had the key in the ignition and wasn't too sure whether the car was on or not. Went ahead and started it up, all went well.
Question is as follows:
If the car was indeed on, could the starter/starter solenoid be damaged or has Infiniti taken any precautions from such possible mechanical mistake?
Also, car wouldn't really start up (engine etc.) if it was already on, correct?
Thanks in advance.
Old Jan 28, 2007 | 06:25 PM
ttrank's Avatar
Grocery getter
The starter would grind. It's not too big of a deal but can harm the starter if you do it for too long or too often.
Old Jan 28, 2007 | 07:18 PM
GM1964's Avatar
Thanks for the response.
Starter didn't grind - car started up as usual.
I'm guessing car must have been off then since it'd grind and wouldn't re-start...
Too much stress!
Old Jan 28, 2007 | 08:43 PM
ttrank's Avatar
Grocery getter
Next time check your tach and see if it is running or get an exhaust so you can hear it.
Old Jun 25, 2007 | 10:25 AM
mediabox's Avatar
some cars are getting smart. i think toyotas and others (maybe ours). the ecu knows when the car is running so if you crank again the ecu prevents the starter from energizing and no grinding.
can anyone confirm?
Old Sep 11, 2007 | 10:30 AM
mediabox's Avatar
we'll i found that at least the 05 g35 (my car) it will grind. not as smart as the toyotas.
Old Sep 11, 2007 | 11:01 AM
luky1380's Avatar
can anyone confirm?
it is true some cars are like that
and on german cars if u crank the car u can't turn key to start possition again unless u turn key back in lock possition
Old Sep 11, 2007 | 10:30 PM
Joe_Camel's Avatar
I'm with Ttrank, I vote exhaust!
Old Sep 12, 2007 | 12:28 AM
AgentAero04's Avatar
Forget the exhaust,install a flashing light on the dash to let you know when it is running.Or walk around to the front and see if your day lights are on.I can't believe this!
Old Sep 12, 2007 | 01:53 AM
Joe_Camel's Avatar
Maybe he has an '03 and it has no 'day lights' (my '03 doesn't)... exhaust FTW.
Old Sep 12, 2007 | 02:15 PM
bythabay's Avatar
even better would be to put in a kill mechanism to the starter so that it doesn't have power if the engine is running.. can be done using a simple relay.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
