skunk2 vs motordyne
Old Jan 31, 2007 | 01:50 PM
dunglan7's Avatar
skunk2 vs motordyne
Is there much of a difference between the skunk2 and the motordyne spacers? I know plenty of people have been statisfied with their motordyne spacers but I have not heard anything about skunk2 spacers. Also will my CAI still fit if I install a spacer?
Old Jan 31, 2007 | 01:52 PM
Floyds_racing's Avatar
I have one(Skunk2) and I see a difference in the top end! I have a friend with a 05 350Z and I pull in the top!!
Old Jan 31, 2007 | 04:15 PM
ttrank's Avatar
Grocery getter
I know the MD has been proven time and time. I would stick with that one until I see another dyno on the same car, same day/conditions.
Old Jan 31, 2007 | 04:17 PM
Hi-TechG35's Avatar
The only thing that concerns me about the spacers from my research is that the Motordyne has a copper insulator and they say that if it snows in your region to use this one. Does the Skunk 2 spacer come with that option and if so or not why is that needed?
Old Jan 31, 2007 | 04:20 PM
ttrank's Avatar
Grocery getter
That's part of the iso-thermal optional kit. Does the Skunk even offer those parts?
Old Jan 31, 2007 | 04:27 PM
Jeff92se's Avatar
Red Card Crew
No but the Skunk is made of a resin/plastic material. The thing about the Skunk is the sizes they sell. I've never seen a dyno sheet using the sizes they offer. They are always thicker than the ones already available from motordyne (which has tons of dyno info). But they are cheaper. I wonder how much to buy and have a machine shop cut one down to one of the more popular sizes? (did I just say that?)
Old Jan 31, 2007 | 04:35 PM
You cant its plastic material and Im working on the Dyno for the Skunk2 but SGP is backed up!!
Old Jan 31, 2007 | 04:37 PM
Jeff92se's Avatar
Red Card Crew
I don't see why you can't machine plastic?
Old Jan 31, 2007 | 04:38 PM
Hi-TechG35's Avatar
Because it never stays the same afterwards especially when dealing with heat.
Old Jan 31, 2007 | 04:41 PM
Jeff92se's Avatar
Red Card Crew
Can't you cool it down with a cooling oil? Like what cnc machines use?
Old Jan 31, 2007 | 04:44 PM
I wouldnt try it I work in a fab shop and I can see that thing wraping like hell!
Old Jan 31, 2007 | 04:48 PM
Jeff92se's Avatar
Red Card Crew
Seems like it's possible? The spacer is a phenolic type plastic right?
http://www.jmjprofile.com/G10_Phenolic_CNC_Maching.htm
Old Jan 31, 2007 | 04:51 PM
Hi-TechG35's Avatar
+1 heres a good example...take a thick plastic ring (ie a soda cap) cut it in half and then heat it up a little bit. What do you get?
Old Jan 31, 2007 | 10:41 PM
ttrank's Avatar
Grocery getter
Does anyone have a dyno for the skunk?
Old Jan 31, 2007 | 10:42 PM
filanj's Avatar
I don't recall ever seeing a Skunk dyno
