Just changed my belts and have a squeak
Old Feb 1, 2007 | 04:57 PM
bluestacy04's Avatar
Ok I just installed two new gates belts. I double and triple checked all the bolts and the tightness of the belts. When I rev my car now around 5k when I let off I get a squeak. Anyone had this before? Any idea's of what to check. The rpms at idel look right at 650. and the squeak is only in the higher rpms! The PS/Alternator belts seems to hop a bit around 5k but the belt is tight!
Old Feb 1, 2007 | 05:44 PM
ttrank's Avatar
Grocery getter
Sounds like it's not tight enough. Or it's too tight and the bearing is going out but that should be more of a constant squeak. Since it's squeaking at higher rpm's it sounds like it's slipping to me.
Old Feb 2, 2007 | 12:28 AM
Not to sure what it was but the squeak seems to have gone away. Thanks though Tim
Old Feb 2, 2007 | 12:45 AM
ttrank's Avatar
Grocery getter
Cool, hope it stays away.
Old Feb 2, 2007 | 08:54 AM
ORANGEBSRT's Avatar
make sure the belt has an inch of play
Old Feb 2, 2007 | 09:59 AM
ok I was wrong it is still there. How would you measure the inch of play??
Old Feb 2, 2007 | 12:27 PM
ttrank's Avatar
Grocery getter
The main drive belt should have 1/4 to 1/2 turn on it. The A/C belt should have ~1/2 turn.
Old Feb 2, 2007 | 01:39 PM
DaveB's Avatar
Take a straight edge along the belt, find the center of the belt between the widest span of the pullies, push the belt in with your finger with about 20 lbs of force, and measure (estimate) the deflection of the belt. 1" of play sounds way too loose to me, but I've never looked up the FSM specs because it's been my experience that these belts last well over 100K miles in most climates.
Old Feb 2, 2007 | 01:41 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
I think they mean one inch of play overall, when you move it up and down, it should have about an inch, so that's 1/2" in either direction. When i do belts, i leave a little less than an inch of play overall.
-GP-
Old Feb 2, 2007 | 02:40 PM
ORANGEBSRT's Avatar
-GP-
he said what i meant. thanx
Old Feb 2, 2007 | 03:51 PM
Thanks guys I'm going to go under my car tomorrow and make the adjustments.
Old Feb 3, 2007 | 12:45 PM
cdub0619's Avatar
I had the same problem with my gates belts. They squeaked only on start up. Took it to the dealership, they said that the belts aren't perfect matches in size because these are aftermarket and gates makes these belts to fit wider aray of vehicles. It's been awhile but I think they said the belts are too tight and they are slipping on the pulleys when the engine is first started or under hard and sudden acceleration. Go back to the nissan oem belts and you will never hear the squeaks again.
Old Feb 3, 2007 | 02:40 PM
ttrank's Avatar
Grocery getter
The quietest belt made are Goodyear Gatorback. I have them on my car and not a sound. They have gaps to help them go around turns. Great product.
snic09
Nov 8, 2017 01:46 PM
Roddy914
Aug 31, 2015 07:07 PM
wuppiedog
Aug 7, 2015 11:16 AM
restrada
Aug 6, 2015 01:44 PM
ddietz97
Jul 26, 2015 06:16 PM
